07-14-2021, 02:19 AM | #1 |
Drives: 2013 Camaro 2SS LS3 Join Date: Apr 2021
NA L99 build (Help!!!)
So last time I posted on here I said I had a ls3 engine, however I came to the realization that I actually had the l99 engine due to is being a automatic. Now I know how dumb that sounds because the ls3 was for the manual, at the time I purchased the car it had the ls3 badging plus I was a HEAVY mopar guy and was not sooo knowledgeable about Chevy motors BUT I am learning. I say all of that to say/ask what are some reliable(daily driver) NA l99 Setups? Please drop some mod list!! Please remember I do want to stay NA but I will go forced induction down the line but not right now
I currently only have a Cai & and a mid muffler delete. I plan on getting LongTube headers from MadHatter garage, a SS1 VVT GPI cam , a ported throttle body and a tune. Am I on the right path? I want to be able to beat scats but continue to keep the car’s reliability. I’m not building a race car. As always I appreciate the feedback and no negativity I’m learning along the way🤝 |
07-14-2021, 04:27 AM | #2 |
L99 and LS3 are pretty much the same so it’s no real big deal to call it a ls3. Some people get upset but who gives a fuk.
I have full bolt ons in my sig and beat scat packs - long tubes and tune go a long way in these cars. Also the rod mod intake by gpi is great and cheap if you send them back your old manifold.
07-14-2021, 06:27 AM | #3 |
GrINned & JUICEd
Drives: 15STI, 10Expy, 10 2SS/RS M6, 47KB1 Join Date: Nov 2009
What mods were done to your car before you purchased it? The previous owner could have done a "LS3 conversion" to the L99. Which makes it similar to a LS3.
07-14-2021, 06:41 AM | #4 |
USA-1
On the L99, if you don't have an aftermarket higher stall converter, you are doing it wrong!
With that cam, I'd run either a 3200 or 3600, it's up to you.
"A Camaro in the garage is safe, but that's not what Camaros are built for..."
R2C CAI / Apex Scoop / VMAX Ported TB / Speed Engineering LTHs / X-pipe / GPI port/rod-mod intake manifold / Circle D 3200 278mm Converter / 3.91 gears / DynoSteve tuned / 1LE Shocks/Struts/Toe Links / ZL1 Rear Sway Bar / Z/28 Trailing arms / Prothane Radius Arm & Subframe Bushings / BMR UCA Bracket, Steering rack bushing / B&M Tranny Cooler / RX Catch Can / Jannetty Tranny Dipstick / 2012+ Heater Hose / 2013+ Rearview Mirror / Fuel rail flip / Drake shifter / Oil Cooler Delete |
07-14-2021, 07:24 AM | #5 |
Evil Genius of Chevrolet
Take a look at my signature. You could do everything except the supercharger and probably get over 500whp. Then you can go FI down the road. Keeping VVT is up to you but I am thankful I kept it. I've been gapping supras, hellcats, M8, M6, corvettes, etc.....
07-14-2021, 10:52 AM | #6 | |
07-14-2021, 11:01 AM | #7 |
You ain't kidding either. My son drove my camaro, I drove my Z06.... he blew my doors off LOL.
07-14-2021, 07:43 PM | #8 |
Drives: 2011 Camaro SS Join Date: Jul 2019
500 whp is difficult to reach in an l99. Im pretty much maxed out on my mods. I dont have an intake or rodmod but i doubt those would make up 45 whp.
EPS CUSTOM GRIND CAM....K@N CAI....VMAX PTB.....FRANKENSTEIN STAGE 2 HEADS ...1 7/8 STAINLESS POWER CATTED LONGTUBE HEADERS...CORSA XTREME 3 INCH CATBACK.....CIRCLE D 3800 Pro Series stall...391 gears.....Ported/modded GPI intake .Forgestar drag pack with Mickey Thompson ET street drag radials AGP PERFORMANCE DYNO TUNED. 463 WHP 428 FTLBS TORQUE.
07-14-2021, 08:34 PM | #9 | |
Oh well, what we lose in rwhp we gain in shift speed, right? If I keep repeating that over and over I might even believe it someday!
07-14-2021, 09:49 PM | #10 | |
Yea us auto guys are at a bit of a disadvantage power wise; the 6l80 is a power sucker for sure. That said the auto still has some pretty decent positives, I wouldn’t mind an M6 SS along side my A6 SS one day.
ABM #2399 2SS/RS:SOLD
07-15-2021, 03:02 AM | #11 | |
Drives: 2010 SS L99 Join Date: Sep 2018
But you and Aqua have to admit, the 1st gear in the auto is nice. When you pair it with 3.91s, a sticky tire and some weight reduction, well, things get spicy haha
Previous PB:11.079 @ 122.99mph.. New setup time: TBD
The 11.079 pass: https://youtu.be/pz27Zq54t_E Build thread - www.camaro5.com/forums/showthread.php?t=555371 |
07-15-2021, 10:37 AM | #12 |
Hell yea it is! Even in stock form it pulls pretty hard out of the hole all things considered. I can’t friggin wait for boost.
07-15-2021, 10:41 AM | #13 |
When mine hits second I usually jump ahead a good car length of most people. 2nd gear is a monster with boost. First is almost like a gear to help it start rolling. It really only stays in first for about one second.
07-15-2021, 01:09 PM | #14 | |
2ss, build advice, l99 engine, ls3 5thgen |
