Go Back   CAMARO6 > Technical Camaro Topics > Cosmetic modifications (exterior and interior)
BeckyD @ James Martin Chevy
Old 03-04-2019, 02:05 PM   #1
VmaxGen2
USN CPO
VmaxGen2's Avatar
Drives: 2021 Camaro ZL1, 2017 Camaro 2SS
Installed new OEM GM ZL1 Rear Deck Spoiler
Another install completed. Bought a new OEM GM ZL1 rear deck spoiler from Matthew at Wildhammer Motorsports. Great price included shipping.
The install was fairly easy. The hardest part was detaching the spoiler once all 6 nuts were removed. The adhesive tape is very strong! I really had to pull hard and carefully at the same time, not easy. Then cleaning the residual tape/adhesive from the deck lid took some effort. Mounting and installing the NEW nuts that come with the spoiler was no problem. The new nuts have seals or gaskets on them to lock the nuts in place and seal out moisture.
I watched Anthonies "The Wrenched Out Garage" video on this install. It's always helpful to see how someone else does a job, you don't have to figure out anything and can pickup good ideas as I did from Anthonie. He used a magnet that most of us gearheads have in our toolbox to FINISH spinning off the nuts once loosened up. It prevents dropping them down inside the deck lid. Thanks Anthonie for great idea.
Then reassembled the inside deck lid liner and polish it up a bit. I'm real happy with how it turned out. I was torn between the wing style and the flipup style, which I also really like.
VmaxGen2 is offline   Reply With Quote
Old 03-04-2019, 05:18 PM   #2
DarkFangz1100
Drives: 2016 Camaro SS
Once you remove the nuts off the bolts rock the spoiler a little to get the seals a little to get googone onto the seals then let it sit for about 5 mins then use fishing line to cut around the seal.
Car looks clean tho! Sometimes I get jealous of other colors lol poor silver ice
DarkFangz1100 is offline   Reply With Quote
Old 03-04-2019, 05:21 PM   #3
Glen e
Retired from Car mfrs....
Glen e's Avatar
Drives: 2LT RS/HR-V
My life with tape projects got immeasurably easier once I started using braid fishing line (30 pound), to just saw it off. Be careful, it'll cut your hands, use gloves.
Old 03-05-2019, 04:59 PM   #4
warren3537
warren3537's Avatar
Drives: 2019 Red Hot ZL1 1LE: 2012 RAM 2500
I added a factory ZL1 spoiler to my 17 1SS, I went with gloss black to accent my hot red paint and having magnetized nut drivers was a big help other than that it was an easy install, and yes the ZL1 spoiler looks better than the stock spoiler.
warren3537 is offline   Reply With Quote
Old 03-06-2019, 01:07 PM   #5
kropscamaro16
kropscamaro16's Avatar
Drives: 2016 1ss camaro
looks good!
Old 03-07-2019, 01:47 PM   #6
Grumpy1
Grumpy1's Avatar
Drives: 2018 ZL1 Hyper Blue A10
Grumpy1 is offline   Reply With Quote
Old 03-07-2019, 04:19 PM   #7
Dysan911
Dysan911's Avatar
Drives: 2017 50th Anniversary 2SS
I did the same myself. Love how from certain angles the wing is just a tad over the edges.
Former Ride: 17 Camaro 2SS, M6 - Fifty | Procharger P1SC | 3.7 Pulley | Stage 2 IC | Race Bypass | DSX FF Kit | JRE Custom E85 Flex Fuel Tune | LT4 Fuel System | JMS Voltage Booster | MSD Plug Wires | American Racing 1-7/8's LT Headers Full System Catback | Baro Breakout Harness | LT4 Map Sensor | Katech Ported TB | MMS Oil Catch Can | 160 Thermo | Solo Performance J-Pipes
Dysan911 is offline   Reply With Quote
