02-13-2020, 03:27 PM | #1 |
Drives: 2018 ZL1 Join Date: Dec 2019
A10 guys - Do you daily paddle shift?
Was just curious if the auto guys drive around in auto, or use the paddles on the daily?
I like both options. |
02-13-2020, 03:53 PM | #2 |
2020 Shadow Gray 2SS
Well my A10 2SS only has 250 miles so far but I've almost exclusively been driving in manual mode with either the paddles or the shifter...
2020 SGM 2SS - A10, NPP, MRC, Red Calipers, Black Camaro Fender Badge, Footwell Lighting
Added after delivery: - GMP CAI, GMP Black Strut Tower Brace, MRR017 1LE Wheels, SS Armrest, Black Fuel Door, Stainless Sport Pedals, SS Wheel Caps, Black Lugs/Locks, GM Splash Guards, DD Smoked LED Markers, Smoked Rear Reflectors, Mishimoto Catch Can, Xpel PPF - Full Front, SunTek 35% Tint, CeramicPro coating, RST Stainless Brake Lines, Castrol SRF, MSD Super Conductor Wires Left: My "fun" ride. Right: My "work" ride: a Gulfstream G600. One's top speed is 180 Mph, the other, 620 Mph... |
02-13-2020, 04:05 PM | #3 |
Drives: 2018 ZL1 Join Date: Oct 2019
The paddles on the A10 are for sh*ts and giggles. Other than that they are useless for anthing else. Just my opinion
2018 ZL1 A10 - Rotofab Intake, LT5 TB, TSP Headers, ATI Balancer, 9.1 Lower Pulley, JMS BAP, Flex Fuel.
02-13-2020, 04:13 PM | #4 |
Drives: '19 ZL1 1LE A10 ShadowGrayMetallic Join Date: Mar 2019
02-13-2020, 04:22 PM | #5 |
Drives: 2019 ZL1 Crush Join Date: Jan 2019
Auto as it shifts quicker than the paddles. I do occasionally manually downshift to get the rev match and gurgles from the exhaust
2019 Crush A10
E-Force 2650 670WHP 615WTQ All besides the 2650 is bone stock down to the air filter. |
02-13-2020, 04:26 PM | #6 |
Drives: 18 zl1 Join Date: Aug 2017
I like seeing if I can be faster than the computer in downshifts. If I can click it fast enough, I can get it to downshift skip 3 gears to slow down, but it doesn't happen often. mostly it downshifts the 3 singularly.
02-13-2020, 04:38 PM | #7 |
Pull and hold the - paddle and the trans will drop to the lowest acceptable gear...
02-13-2020, 04:42 PM | #8 |
02-13-2020, 06:18 PM | #9 |
Drives: 2020 Camaro ZL-1 1LE Join Date: Jul 2018
+1, the A10 always has the transmission in the right gear. Amazing transmission.
Home Track: NCM Motorsports Park
02-13-2020, 06:36 PM | #10 |
It won't go to 1st, it'll jump down about 3 gears or so and run you up to about 4500 RPM...
02-13-2020, 08:07 PM | #11 |
Drives: None at the moment Join Date: May 2018
Yeah the vette and camaro auto paddles are a gimmick. On the Challengers and the new A10 mustang, they actually react in real time to shifts. But they are hot garbage in the camaro and vettes.
02-13-2020, 09:01 PM | #12 |
Drives: 18 ZL1 nightfall grey A10 Join Date: Apr 2018
Auto all the time.
02-13-2020, 09:58 PM | #13 |
Drives: 2019 ZL1 Join Date: Aug 2018
Manual mode only for autox or the very rare downshift in a turn or lane change because sometimes adding a lot of pedal gets a bit too aggressive of a gear.
02-13-2020, 10:47 PM | #14 |
Drives: 2018 ZLE (M6/hyper blue) Join Date: Nov 2015
Manual mode allows you to go higher in RPMs than auto mode; if you're checking your times, manual mode is the better route to take it up to the top end of the range. Pretty sure I saw motor trend or car & driver, or something similar anyways, saying that as well (they lowered their 0-60 test times significantly using manual mode).
