07-28-2013, 04:43 PM | #1 |
Drives: 2013 2SS Join Date: May 2013
Nitrous setup cost
Just curious as to what a full setup installed and tuned would cost. 100hp shot, 10lb bottle, heater, opener, mount, and timing module. Every little thing needed. Including all safety measures needed.
07-28-2013, 05:16 PM | #2 |
Drives: 2013 SS Join Date: May 2013
Between 700 to 1300 or so, buddy paid 1300 that was a plate system with pills to hit 100 150 200 250 and 300. 10lb bottle Nitrous Outlet kit and tuned etc.... window switch included
07-28-2013, 05:21 PM | #3 |
Drives: Black 1SS/RS LS3 M6 "The Toy" Join Date: Dec 2011
I payed 925 for the nitrous express system, still need timing retard lingengelter $275, colder plugs, bottle warmer $200, bottle opener $200, control panel for bottle opener purge heater arming another 100.
2010 1SS/RS Diablo Sport Trinity JRE Tune OBX headers with Cat delete Borla Cat back Volant PowerCore CAI BMR adjustable trialing arms 4.11 Gears JRE cam package.
07-28-2013, 05:24 PM | #4 |
Drives: 10' 2SS LS3 M6 Join Date: May 2012
to do it the safest/easiest possible with WOT/window switch and C16 standalone, somewhere in the $3k range
07-28-2013, 07:09 PM | #5 |
chevy pride
kit price / lnc 2000 / window switch . most windows switches have a wot made in.
i have a 90mm plate kit , lnc 2000 and nos launcher and its a killer setup. nos launcher is a progressive shot. with lots of options. but if u plain on anythign over a 250 go direct port . if u dont got past 150 no need for a fuel system.(standalone). u will also want get a diff fuel line to the rails. its know to lean out on the hit. but with the setup i have . u can change ur timing / u will have a 2step. u can run 2 stages and a shift light. tons of stuff u can do with the setup i have. i got about 1500 in mine.
check out ky speeds fb page https://www.facebook.com/kyspeed |
07-28-2013, 07:36 PM | #6 |
V8 Lounge member #2
Drives: 2001 Ws6 Join Date: Sep 2009
^^agreed
2001 ws6, 40k miles, Ls3 416 stroker, short block built by PER the rest by me. LPE Ls3 heads milled to 12-1 comp, FAST 102, NW 102, kooks 2", dual DMH cutouts, Magnaflow C/B, BTR cam + springs. Full UMI suspension.
07-28-2013, 08:13 PM | #7 | |
Drives: 2010 Camaro Join Date: Feb 2010
The $3000+ mark is a gd start to make it the very best possible. You can cut stuff out like the remote opener to start cutting cost. |
07-28-2013, 09:18 PM | #8 |
I highly suggest a NANO setup vs a bottle heater. I am currently playing with a 200 shot plus nano on my car. Over 700 rwhp, and it will maintain 950 psi for the entire bottle.
I would suggest a zl1 pump for cammed guys spraying over 100. Pick a kit you like (nitrous outlet has some sweet setups), br7efs, lnc2000, and either a dedicated fuel system for race gas, or run some race gas in the tank. that's what I do. Run down to fuel light, and add 5 gal of MS109, but since that fuel is oxygenated you have to run about 4% richer. C16 is popular too, but I like to run the unleaded fuel. |
07-28-2013, 09:24 PM | #9 | |
