AWE Tuning
Old 02-14-2020, 03:57 PM   #15
eimarshall
eimarshall's Avatar
Drives: 2018 SS 1LE Hyperblue
Nevermind, found another thread with the info.
eimarshall is offline   Reply With Quote
Old 02-25-2020, 12:48 PM   #16
JacobC1983
JacobC1983's Avatar
Drives: 2019 ZL1
The RE71R in 295 30 R 20 fits on stock ZL1 (non 1LE) 20 inch wheels, correct? Do they rub at all in the front?
JacobC1983 is offline   Reply With Quote
Old 02-25-2020, 05:11 PM   #17
Scargoes
Scargoes's Avatar
Drives: 2018 Hyper Blue 2SS 1LE
Originally Posted by eimarshall View Post
Thanks for the advice folks. I ended up going for the RE71s.
Anyone have recommendations on cold/hot pressures for autoX? I found the Goodyears were pretty good right around 29 cold / 33 hot. Similar numbers for the Bridgestones? or something different?
I'm at -2.7* camber f and -1.8* camber r, 0* toe f and 0.2* toe in r and run 32 to 33 psi in the fronts and 30-31psi in the rear. Bleeding off pressure as heat builds. I run the same pressures in the Rivals.
The March practice day is coming soon so I'll have some comparative testing between the Rivals and RE71Rs done and reply with my results here in this thread.
2018 Hyper Blue Metallic 2SS 1LE with Nav, PDR, and track alignment
1:34.20 Willow Springs Big Track
Scargoes is offline   Reply With Quote
