Old 05-17-2021, 07:49 PM   #1
l.o.d_yankee
l.o.d_yankee's Avatar
Drives: 2010/2SS/M6/440ci
L.o.d performance ver.3 X1 manifold
L.o.d performance X1 manifold (version 3) throttle body option of 103 or 105mm. In stock
2010 2SS Camaro - Engine: 5.3 aluminum Re-sleeved 4.185 bore, 4 inch stroke, 12.5:1 compression, 440ci, SPS Dart pro1 ls3 heads, tsp ls7 stage 4.2 cam(too small), "billet bill" original X1 manifold, bbk 102mm, cai cold air. Exhaust: TSP 2 inch primaries, V-band merge, hooker blackheart x pipe (modified) spintech 9000 mufflers. Drivetrain: Dss 1 piece driveshaft, MGW shifter, Z28 clutch, ram aluminium flywheel. Body: ZTA spoiler, de-badged, ZL1 front bumper, 14-15 mohawk, two tone paint.
l.o.d_yankee is offline   Reply With Quote
Old 05-17-2021, 08:46 PM   #2
eLeSthree
Drives: 2011 Camaro SS 6sp
Very nice. Sorry if this is common knowledge but how much higher is the center of the TB placement with this intake?
2011 Camaro SS---SOLD
TMS Dart 427 FED M311s, ESS Tuning G4 Blower, DSX Triple FP Assembly, DSX FF, FIC1300, Mcleod RXT 1200HD, Edlebrock Pro Flo XT
1158whp 1017wtq.
2010 CTS-V A6 - "Stock" SOLD
630whp 658wtq
2024 F-150 RCSB 5.0 4x4
waiting for tunes...
eLeSthree is offline   Reply With Quote
Old 05-17-2021, 09:16 PM   #3
l.o.d_yankee
Its approximately 2 inches higher then say a ls3 manifold. Fit is perfect on 5th gens 90%of existing cold air fit up still
Old 05-18-2021, 04:04 AM   #4
Bigdumogre
Bigdumogre's Avatar
Drives: 2012 Camaro SS
Any cutting needed it larger hood?
Bigdumogre is offline   Reply With Quote
Old 05-18-2021, 05:46 AM   #5
Clarkstar
Clarkstar's Avatar
Drives: 2013 1SS 1LE
No cutting, fits under the strut tower brace too
603 h.p. 495 ft lbs tq.
Clarkstar is offline   Reply With Quote
Old 05-18-2021, 06:48 AM   #6
Bigdumogre
Bigdumogre's Avatar
That’s awesome
Any dyno numbers and charts comparing it to stock/high ram?
Old 05-18-2021, 08:09 AM   #7
l.o.d_yankee
Clark beat me to it, no cowl or hood cutting. Zl1 guys will have to trim the drip tray a little. 14-15 guys have to remove the lower drip tray
Old 05-18-2021, 08:12 AM   #8
l.o.d_yankee
That’s awesome
Old graph from the manifold shootout at gpi. This was on a sbe ls3
Old 05-18-2021, 08:56 AM   #9
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
Man Raf, those are just an amazing piece of equipment!! I really love mine!! Thanks. I need to give you a call soon as I am going to swap out my 92 snout still for the 103 and do the NW 103mm TB... Good to see ya back on..
Old 05-18-2021, 09:00 AM   #10
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
Here is mine with the K&N CAI..
Old 05-18-2021, 09:08 AM   #11
Bigdumogre
Bigdumogre's Avatar
Think this might be my front runner option now when I go boosted
Old 05-18-2021, 09:24 AM   #12
l.o.d_yankee
Thank you sir and I forgot yours was a 92mm you see some significant power with a 103 on the engine dyno it was around 20hp
Old 05-18-2021, 10:44 AM   #13
Chris49066SS
Chris49066SS's Avatar
Drives: 2010 SS L99
Raf would you put any value in having the insides of the X-1 polished?
Previous PB:11.079 @ 122.99mph.. New setup time: TBD
The 11.079 pass: https://youtu.be/pz27Zq54t_E
Build thread - www.camaro5.com/forums/showthread.php?t=555371
Chris49066SS is offline   Reply With Quote
Old 05-18-2021, 10:54 AM   #14
l.o.d_yankee
Ehhhh perhaps in the most extreme cases. Max, max effort. There's plenty of material in the runners for those that want to venture into 6 bolt head territory.
