Vararam
Old 06-25-2013, 01:16 PM   #1
njweatherman
Drives: 2018 Camaro 2SS, redline edition
Why does my exhaust quiet down?
I have a 2013 2ss automatic Camaro with the following mods:
flowmaster catback outlaw exhaust
k&n tyhpoon cold air intake
Range AFM disabling product
When I step on the gas, my car sounds nice and loud; however, when I do not have my foot on the gas, the exhaust sounds noticeably quieter.
Is there a way to increase the sound of the exhaust when I do not have my foot on the accelerator?
njweatherman is offline   Reply With Quote
Old 06-25-2013, 01:35 PM   #2
patternpilot
patternpilot's Avatar
Drives: 2012 2SS/RS
Well this is how I see it. The exhaust slows down during idle. When you speed the motor up the exhaust speeds up and the mufflers do not have time to absorb the sound, thus allowing more sound to pass by. Less muffler will allow more sound. I have Corsa exhaust and after the mods it was pretty loud all the time. I installed a Magnaflow muffler to the pipes in the tunnel. During idle it is very quiet, but during acceleration it comes alive.
There's more to life than gas mileage
LS3, Whipple, Custom Comp Cam, springs, pushrods, timing set, CAI intake, Apex cold air scoop, Doug Thorley TRI-Y headers, Billet Custom Products baffled Valve covers, Mighty Mouse Catch can, ADM FPCM, ZL1 fuel pump, MSD boost-a-pump, Hex Vent hood vents, ProSport gauges(fuel pressure, AFR, Boost), Corsa, 100 cell Cats. Jannetty remote tuned, Pfadt trailing arms, all parts user installed. No Dyno yet. Manual trans. 3.45 gears.
patternpilot is offline   Reply With Quote
Old 06-25-2013, 02:00 PM   #3
Bell040
Bell040's Avatar
Drives: 2SS/RS - Black - GFX
Are you referring to active fuel management (AFM)?
This is when your engine switches into 4 cylinder mode.
Ordered: 10-13-08
Built: 3-30-09 (#1691)
Recieved: 6-12-09
Blacked out, Cammed (Lunati Voodoo 233/245, .578/.598 @114°, +4°), ARH LTs, VR OTR CAI, Cutouts, and lots of other fun mods.
Bell040 is offline   Reply With Quote
Old 06-25-2013, 02:17 PM   #4
mikeyg36
Drives: 2015 Z/28 #533
Umm if you're not giving the car gas it won't get louder. It's basic car knowledge.
Old 06-25-2013, 02:30 PM   #5
Apex Motorsports
Apex Motorsports's Avatar
Drives: 2000 Camaro SS
The volume and velocity of the exhaust gases slow down so there is less sound. Kind of like when you blow a whistle harder or softer.
Old 06-25-2013, 02:44 PM   #6
Denis
Denis's Avatar
Drives: 2010 SS
this
if your not on the gas, your not making power...therefor no sound
Denis is offline   Reply With Quote
Old 06-25-2013, 02:46 PM   #7
vroomapunk
[COTW 5/12/14]
vroomapunk's Avatar
Drives: 2012 CRT NF Cammed 2SS/RS For Sale
And you can think of it in terms of RPMs. Blow the whistle once every 10 seconds, or blow the whistle every second. A lot more noise.
You need to read up on exhuast before you go modding. Headers, cats, mid pipes/resonator, and mufflers all effect the sound. (tips do too, but not much).
An intake can change the tone as well
vroomapunk is offline   Reply With Quote
Old 06-25-2013, 02:57 PM   #8
joeybsyc
joeybsyc's Avatar
Drives: 2010 Aqua Blue Metallic 2SS
Exhaust not as loud when you're off the gas pedal? Who'd have thunk it?
joeybsyc is offline   Reply With Quote
Old 06-25-2013, 03:06 PM   #9
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
That's cause your using a low flow K&N hotair kit!
Switch to a highflow Cold air kit like CAI, ADM, rotofab and it will make your car louder even at idle!
Oh and the "range won't help you" Tune it.
2001 ws6, 40k miles, Ls3 416 stroker, short block built by PER the rest by me. LPE Ls3 heads milled to 12-1 comp, FAST 102, NW 102, kooks 2", dual DMH cutouts, Magnaflow C/B, BTR cam + springs. Full UMI suspension.
litle88 is offline   Reply With Quote
Old 06-25-2013, 03:33 PM   #10
njweatherman
Thanks for the input guys. I just remember my previous 2001 Mustang GT was always loud, even at idle and when I did not have my foot on the gas pedal.
Old 06-25-2013, 03:58 PM   #11
strych9
I'll be back...
strych9's Avatar
Drives: Subaru, HD Road Glide Special
Bye bye, Bumblebee!
strych9 is offline   Reply With Quote
Old 06-25-2013, 04:30 PM   #12
Mchlgrrsn
Stroked and blown
Mchlgrrsn's Avatar
Drives: 2010 LS3 2SS
If its manual ... Just push the clutch down use the handbrake and keep your foot on the gas, I think that will work.
LME 416 LS3 shortblock/Callies Compstar 4340 4"crank/Callies 6.125 H beams rods/Wiesco 4.07 forged pistons/Cam Motion custom LS1/LME ported heads /maggie TVS2300/I West 8rib 10%OD /3.2 pulley/OD cog drive/JRE tensioner/ID850 /ADM dual fuel/Kooks LT 1 7/8/magna flow2.5 /cat delete/Roto Fab CAI /MGW short throw /SPEC super twin clutch/G Force built trans,carbon syncro rear shaft upgrade /DSS 9"single CF DS /Strange 3.70/31 spline trutrac/MT DR's/earls oil cooler /tuned KHC
Mchlgrrsn is offline   Reply With Quote
Old 06-25-2013, 04:50 PM   #13
MrGs SS
MrGs SS's Avatar
Drives: 2013 Black SS/RS
You have to be kidding...
2013 2SS Black~ L99
Performance Mods-CAI intake, APEX washer bottle relocate and scoop, Ported TB. SLP 160 degree stat, Norris Catch-can, Pfadt Tri-Y headers, BMR F/R sway bars and Arms, Corsa cat back exhaust.
Appearance Mods-Blackout kit (markers, tail lights), black tail light bezels, black chrome trunk lettering, LSR billet engine dress-up kit, sub box. Billet tensioner pulley and thermostat housing (Billetcustom), Heritage grille.
Tuned by Matt @ Florida Speed and Power
379/388 Mustang dyno
MrGs SS is offline   Reply With Quote
Old 06-25-2013, 05:02 PM   #14
Warpaint69
Drives: 2013 VR 2SS RS
Sorry, but the Range does help those not wanting a tune. It works, enough said.
Warpaint69 is offline   Reply With Quote
