AWE Tuning
Old 01-31-2019, 08:02 AM   #1
Dgarcia
Drives: 2017 Camaro SS Convertible
Angry 2017 Camaro SS humming noise
2017 Camaro SS Humming noise
I need some help. A humming noise has been overwhelming on my car rolling at 65 mph on deceleration. The dealer says its uneven tire wear. At this point I have already ruled that out because when I turned it on this morning I was disturbed by this loud humming noise that happens sometimes when I'm driving as well. Dealer cant figure out what it is. Does anyone have any idea on this? This noise is very annoying!!
Dgarcia is offline   Reply With Quote
Old 01-31-2019, 08:26 AM   #2
crosive
Drives: 18 zl1
can you be a little more specific as to the origin? speed related? rpm related? constant hum or variable? do you have the bose stereo?
crosive is offline   Reply With Quote
Old 01-31-2019, 08:38 AM   #3
Dgarcia
Humming noise happens every now and then on cold startup then while driving 65 mph on deceleration. No Bose stereo on this 1SS
Old 01-31-2019, 08:39 AM   #4
Dgarcia
Usually hear it on the right side of the car but as it gets louder its difficult to hear where it's coming from...
Old 01-31-2019, 09:18 AM   #5
DangerZL1
Drives: 2023 Black ZL1 Auto
When you say deceleration, do you mean completely off the gas and letting it coast to slow down? If the noise stops when you're off the gas it may be the rear diff. Tires can easily make noise, but an alignment that's off can also cause the tires to make noise. Have you had the alignment checked? I'd have it checked to rule it out.
DangerZL1 is offline   Reply With Quote
Old 01-31-2019, 09:22 AM   #6
Dgarcia
What does my alignment have to do with the noise happening at startup?
Old 01-31-2019, 09:28 AM   #7
ctrlz
Automatic or manual transmission? This sounds like transmission noise.
Old 01-31-2019, 09:30 AM   #8
Dgarcia
Automatic. First 2 times they just flushed the transmission and blamed it on the tire wear,but when the noise happens at startup thats throws their opinion out the window. They also said it might be the torque converter. I like yes,but in park???
Old 01-31-2019, 09:34 AM   #9
ctrlz
Does the noise change when you shift out of park into drive or reverse?
Also, since it hums while in park, does the sound change when you open the hood? I suspect that if any belt-driven components (e.g. alternator) were the problem it would be louder with the hood up.
Old 01-31-2019, 09:48 AM   #10
Dgarcia
It hums in park but not all the time. This morning was over whelmj g though..lol when I'm at 65 mph(usually when it hums) then shift to neutral it goes away
Old 01-31-2019, 09:56 AM   #11
ctrlz
well... not tires for sure then.
If shifting changes the noise, then I really lean toward transmission or torque converter.
Old 01-31-2019, 09:56 AM   #12
drperry
Drives: Chevy Blazer
The torque converter is always moving, no matter what gear you're in... Or at least it used to, lol.
It does sound like the torque converter, if neutral made the noise stop (sudden reduction in noise), but could also be a loose/worn mount, or something in the serpentine system...
But I'm leaning towards transmission.
Can you try and record the hum?
Sent from my SM-G965W using Tapatalk
drperry is offline   Reply With Quote
Old 01-31-2019, 11:02 AM   #13
ctrlz
I agree, but shifting does change the loading on a whole bunch of components
Old 01-31-2019, 11:41 AM   #14
coruiz
Drives: 2018 Camaro 2SS Hyper Blue
video?
2018 Camaro 2SS
| Hyper Blue Metallic | A8 | NPP | MRC | NAV | HUD | ATAK |
coruiz is offline   Reply With Quote
