10-06-2022, 02:29 AM | #1 |
piston wear
What caused this? Essive heat, low oil pressure. high mileage, or too much fuel?
10-06-2022, 02:54 AM | #2 |
Drives: 2010 2SS LS3 and 1978 STROKER 383 Join Date: Feb 2018
This is a result of the engine overheating.
I would like to see the cylinder wall after this piston
My life is a constant struggle with Camaro.
K&N CAI, Stainless Power longtubes, high flow cats, modified Ragazzon High Performance axle back, Soler Performance ported throttle body, Soler Performance throttle controller, RAM clutch adjuster, modified LS7 clutch kit, Tick Performance billet bearing support, Tick Performance remote bleeder, separate clutch reservoir, BMR trailing arms, BMR toe rods, Pedders Suspension cradle bushing inserts, Control Arm Bushings, Strut tower brace, oil catch can, Hurst T-handle shifter, 20mm wheel spacers, DBA brakes, QTP Cutouts, Dynosteve tune. |
10-06-2022, 03:05 AM | #3 |
The cylinder wall just barely cleaned up with .005 of honing.
10-06-2022, 08:33 AM | #4 |
How many miles? Is it scuffed up or smooth? Kinda hard to tell from the picture. It’s not uncommon for them to wear thru the coating like that, especially with some mileage. As long as it’s not scarred or scuffed up I wouldn’t worry too much.
ABM #2399 2SS/RS:SOLD
10-06-2022, 08:54 AM | #5 |
Drives: 13 CAMARO 2SS LS3-04 SILVERADO LS3 Join Date: Dec 2021
I concur with Blue, looks like just about every one I've had apart.
10-06-2022, 01:53 PM | #6 |
I'm not entirely sure if that's okay.
Ok I consider this... But this is already quite a lot of damage for my taste. Looks like pistons from my overheated 78. 0.005 you're pretty lucky when I see the bitten piece of piston under the lower wiper ring.
10-06-2022, 03:33 PM | #7 |
Sporting Foole
Drives: 2010 Camaro SS Join Date: Sep 2019
Man? That section under the oil ring is ugly AF?
10-06-2022, 04:47 PM | #8 |
That was with 170k miles. And it was feeling like almost like a piece of fine grit sand paper. If you look at my build thread (2012 N/A Build) you'll see he got the cylinders pretty nice with the .005 hone.
10-09-2022, 09:31 AM | #9 |
Long Live Chevy Camaro!
Drives: 2014 Camaro LT2/RS Join Date: Jun 2011
That scoring is not that bad... This is one of the pistons on my "other car". Engine will have to be resleeved.
10-09-2022, 09:46 AM | #10 | |
10-09-2022, 06:58 PM | #11 |
Yes sir I feel like I got pretty lucky on this one. I think if I had went any further on this engine I would have to have it bored to 4.075.
10-09-2022, 06:59 PM | #12 |
Damn buddy that looks pretty bad.
10-11-2022, 12:38 AM | #13 |
Here's where the valve hit the piston on all cylinders. I don't know why the factory didn't put the valve reliefs on both sides across from each other? I'm guessing it's attempt to save money. That way they can install the piston up or down and the relief be on the same valve which I believe is on the intake side.
10-11-2022, 08:00 AM | #14 |
Fast Cars and Old Guitars
I guess things can always be worse. Here’s a clip that could’ve been titled, “Piston Where?”
https://youtu.be/WBWJhekqPmc
