01-28-2021, 07:43 PM | #1 |
Drives: 2010 Camaro SS Join Date: Jan 2021
LS3 Cam Questions
Thanks EVERYONE!!!
01-28-2021, 09:25 PM | #2 |
So you’re looking for sound as a determining factor? Sound is subjective, but I personally wouldn’t use “sound” as a deciding choice. That’s a TSP stage 1 cam. If the car is being babied, would you even notice the torque?
Here’s the same cam on a vette https://youtu.be/fxLiMfUIN_Q
01-28-2021, 11:23 PM | #3 | |
Drives: 2014 2SS/RS Join Date: Jan 2018
Sent from my SM-N986U using Tapatalk
2014 2SS/RS LS3/M6
01-28-2021, 11:57 PM | #4 |
Give speed a chance
Before you go digging into a well running engine with only 30K on it why not just do the bolt-ons you mentioned? Headers, cat delete and aggressive mufflers may be all that's required to get what you're after in the decibel department. Throw in some 3.91 gears for added torque multiplication with a good tune to tie everything together and life's good!
01-29-2021, 02:24 AM | #5 | |
Drives: 2010 2SS LS3 and 1978 STROKER 383 Join Date: Feb 2018
01-29-2021, 03:46 AM | #6 |
Drives: Ashen grey, 1SS, L99 Join Date: Aug 2016
A cam adds chop, and if he’s looking for chop a stage 1 won’t have a lot. As said above do a stage 3.
Roto-fab CAI, Nick Williams 102mm TB, LOD X1 V3 intake manifold, GMPP LS3 heads, Night Fury cam, TSP 2” long tubes, Corsa ZL-1 catback, Nitrous Outlet 102mm plate kit/150 shot, NGK BR7EF plugs with Taylor plug wires, DSX flex fuel kit, ZL-1 fuel pump and injectors, B&M deep trans pan, Yank 3400 converter, 3.45s with BMR Delrin bushings, mishimoto 169° Thermostat, GM ground effects, T-Rex upper grill, Z/28 Spoiler, Lolly pop Lime brake calipers, ZL1 10 spoke wheels, 12” subwoofer, and custom paint matched interior.
01-30-2021, 11:21 PM | #7 |
Drives: '11 Camaro 2SS Blk w orange stripes Join Date: May 2011
CAM
I had a stage 3 BTR cam install done. My speed shop said it was the best one they had seen.
cam, ls3 5thgen |
