08-19-2020, 01:19 PM | #1 |
Would 315s fit on a 10" rims?
I have a set of 2017 zl1 reps and I think the size of them are 9s on the front and 10s on the back, if that's actually my rims size do you think I can fit 275x35r20 on the front and 315x30r20 on the back? I'm not using the car for drag or anything hell it's a v6 and for us v6s most what we can do is improve the look of the car -yes I know there's tunes like overkill but if I'm spending $7k on mods I'd rather put on a v8.
P.s my current are 245x40 front and 275x35 back. |
08-19-2020, 01:22 PM | #2 |
Drives: 2014 2SS/RS Join Date: Jan 2018
Will they fit? Sure. Is it ideal? no.. when you squeeze a tire between a smaller wheel, it bulges the center out. Some tire shops will mount it and some won't.
2014 2SS/RS LS3/M6
08-19-2020, 01:26 PM | #3 |
315's are not recommended on 10" wheels. They should be mounted on 11" wheels.
08-19-2020, 01:29 PM | #4 |
Drives: 2014 2SS/RS/1LE Join Date: Mar 2015
I'm not sure about where you are at but in the US most reputable tire shops will not mount a 315 tire on a 10" wheel.
08-19-2020, 02:54 PM | #5 |
They would be fine
08-19-2020, 03:15 PM | #6 |
Thanks everyone for clearing it the shop I went to said he can fit them but apparently he just wanna sell some wheels, how about the 305s? Is it the same situation?
08-19-2020, 03:32 PM | #7 |
I have ran 315's on 10 inch wheels for 6 years with no issues! Now I run them on 11 inch wheels and they look better. On the 10 inch wheels I have even been to the dragstrip with them, no problem. Like they said, 11 is optimal size for them. I even have a set of 11.5's with MPSS 335's on them I swap out every once in a while to change things up.
08-19-2020, 04:52 PM | #8 | |
