Old 03-15-2021, 03:57 PM   #1
GhostOutlaw
Drives: Black 2011 2LT/RS
Daily Dead Battery
I have something draining my battery and no one seems to be able to find it.
3 new batteries, a new alternator and I still come out to a dead battery every other day.
WTF is draining my battery and why can 3 mechanics not figure it the **** out?
I need a real solution or I'm actually going to have to buy a new car over what's probably a $5 issue.
Anyone any thoughts?
GhostOutlaw is offline   Reply With Quote
Old 03-15-2021, 04:21 PM   #2
gtstorey
There has been some discussion on here of a bluetooth phone trying to pair after the car has been cutoff draining the battery.
Old 03-15-2021, 04:24 PM   #3
GhostOutlaw
My bluetooth has been acting funny lately, often freezing up.
My trunk button also no longer works.
Old 03-15-2021, 05:12 PM   #4
Mouse330
Mouse330's Avatar
Drives: 2011 2SS, 2006 GMC Sierra
The Telematics Communication Interface Control Module can be an issue.
In the Instrument Panel fuse block you can pull fuse 14 (onstar) and see if that makes a difference. There's a ton of things that can drain a battery. I use a low amp probe to check the milliamp draw. A lot of shops shy away from battery draw issues.
Mouse330 is offline   Reply With Quote
Old 03-16-2021, 06:19 PM   #5
Supreme23
Drives: 2012 Chevy Camaro RS
like Mouse330 said there are a bunch of things that can drain a battery. at this point after going through 3 something is eating through them - you just have to go one by one and find out what is drawing what. have to probe for something because there is something drawing thats killing those batteries.
Supreme23 is offline   Reply With Quote
Old 03-17-2021, 09:53 AM   #6
ElderJ
ElderJ's Avatar
Drives: 2014 Camaro 1LT
Find a more thorough and reliable mechanic. Electrical issues on cars in this generation can be a beast to diagnose, so it's my understanding that most mechanics are just looking for a quick-fix patch job and praying rather than systematically diagnosing current/voltage at fuses, relays, etc.
ElderJ is offline   Reply With Quote
Old 03-17-2021, 10:56 AM   #7
Army of Wuzzy
Army of Wuzzy's Avatar
Drives: 2011 Chevrolet Camaro LS
my buddy had a similar problem in his truck. A wire's sheathing had rubbed off and was making contact with the chassis
"If you aren't first, you're last"
-Ricky Bobby
Army of Wuzzy is offline   Reply With Quote
Old 03-17-2021, 10:59 AM   #8
gtstorey
Judging by other issue with the trunk release button not working, I would check the wiring harness going into the door if you can't narrow it down with pulling fuses.
Old 03-17-2021, 07:19 PM   #9
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
^^^^ This, I have seen where the cables from the battery to the front of the car had worn thru somewhere along the line and was grounding out and draining the battery. Find a shop that will, or can do a voltage load test on BOTH cables.
Old 03-22-2021, 06:54 PM   #10
IOM Bullet
Drives: 2010 2SS RS LS3
My friends Porsche has an electrical draw somewhere. I sent him a video from The Car Wizard on YouTube. Pretty detailed and straightforward way to find draws in your cars electrical system. Definitely worth a view. Hope this helps.
IOM Bullet is offline   Reply With Quote
