Old 01-26-2021, 12:10 PM   #1
ElderJ
ElderJ's Avatar
Drives: 2014 Camaro 1LT
Tire Pressure Reading
Not sure if this is considered Mechanical or not, so I'll try my hand in the General forum.
How reliable are the electronic TPM sensors?
I'm accustomed to checking my tires with pencil gauges, but they are hit and miss with some of their readings, and I figured if the car is doing the work for me, then why bother.
ElderJ is offline   Reply With Quote
Old 01-26-2021, 12:27 PM   #2
Mr_Draco
Mr_Draco's Avatar
Drives: 2SS/RS
Mine normally are within 2-3 psi of what my gauge says when I check them. Sometimes the car is higher, sometimes lower. I wouldn't rely on them to get an accurate reading of exact psi, just use them as a quick reference of if they need air or if you have a flat.
Mr_Draco is online now   Reply With Quote
Old 01-26-2021, 12:50 PM   #3
TheFlyingBananaSS
Evil Genius of Chevrolet
TheFlyingBananaSS's Avatar
Drives: 2017 Z06, 2019 XTS, 2013 SS
I use an analog gauge for mine. Mine is usually within 1psi of the tpms when cold.
TheFlyingBananaSS is offline   Reply With Quote
Old 01-26-2021, 12:57 PM   #4
ZED SLED
ZED SLED's Avatar
Drives: 2017 Mosaic Bk ZL1 M6
TPMS on all my vehicles typically read about 2 psi less than any of my actual gauges
Old 01-26-2021, 02:37 PM   #5
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
Same here, I just installed new TPMS's, old ones lasted 10yrs, and the dash readout is within 2 psi of what my dial gauge would read at the tire when warmed up or cold.
Old 01-26-2021, 08:25 PM   #6
ElderJ
ElderJ's Avatar
Thanks fellas
Old 01-26-2021, 08:50 PM   #7
Moto-Mojo
Fast Cars and Old Guitars
Moto-Mojo's Avatar
Drives: 2015 2SS RS (L99, baby!)
I too found the TPMS sensors pretty close to the 'analog' gauge.
Moto-Mojo is offline   Reply With Quote
Old 01-27-2021, 07:13 PM   #8
LimaCharlie
LimaCharlie's Avatar
Drives: 2011 Camaro SS/RS - 2004 Silverado
Same here. I notice the same thing.
I think the TPMS sensors are actually designed to show less than actual pressure. This will trigger a low pressure warning well before the ACTUAL tire pressure is dangerously low.
2011 Summit White Camaro 1SS/RS
-6.2 LS3, TR6060, 3.45, G80
2004 Black Silverado 1500 2WD Regular Cab, Short Bed
-5.3 LM7, 4L60E, 3.42, G80
2014 White Caprice PPV
-6.0 L77, 6L80E, 2.92, G80
LimaCharlie is offline   Reply With Quote
Old 01-27-2021, 07:23 PM   #9
supersnake05
supersnake05's Avatar
Drives: 2015 Camaro SS 1LE, 2014 Chevy SS
Toyotas have a low pressure threshold set around 27.5 psi to set tire light. They are pretty close to car and my digital gauge at work. I wouldn't say set lower cause then tires would be over inflated a bit going off car gauges.
supersnake05 is offline   Reply With Quote
Old 01-27-2021, 08:03 PM   #10
BuddyLee
BuddyLee's Avatar
Drives: 2013 Camaro 2SS/RS
The right front reads 24 on the dash but 42 with a TPG.
BuddyLee is offline   Reply With Quote
Old 01-28-2021, 08:21 AM   #11
ChibiBlackSheep
ChibiBlackSheep's Avatar
Drives: 2012 2SS/RS, 1968 SS
Do all of your tires read correct? They weren't rotated and never paired were they?
2012 Camaro 2SS/RS | 1968 Camaro SS | 2020 Cadillac CT5 Premium Luxury | 2021 Spark LS
ChibiBlackSheep is offline   Reply With Quote
Old 01-28-2021, 09:01 AM   #12
ariZona28
Give speed a chance
ariZona28's Avatar
Drives: 2015 Camaro 2LS, 2015 Camaro Z/28
I would think that 24 on the dash would give you a warning. May want to do the "re-learn" procedure. My '15s require a special tool. Not sure about your '13.
ariZona28 is offline   Reply With Quote
Old 01-28-2021, 09:04 AM   #13
TheFlyingBananaSS
13 needs the tool too. $15 on ebay
Old 01-28-2021, 09:34 AM   #14
BuddyLee
BuddyLee's Avatar
As you know a complete rotate would not work but a left to right swap would be a good idea. This will be a project for this weekend. Thanks for the tip.
