Vararam
Old 08-11-2020, 03:20 PM   #1
Camaro_Fuzion
Camaro_Fuzion's Avatar
Drives: 2022 Chevy Camaro 2SS Redline
What is the proper way to clean a Camaro engine bay?
What is the proper way to clean a Camaro engine bay? Which vital components are you covering up to prevent damage from soap and water?
Camaro_Fuzion is offline   Reply With Quote
Old 08-11-2020, 03:32 PM   #2
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
I just use a micro fiber cloth and some detailing spray and wipe EVERYTHING I can get to.
Old 08-11-2020, 04:25 PM   #3
SSFury
My Road Rage is Legendary
SSFury's Avatar
Drives: 2011 IOM 2SS/RS "Fury"
That looks good.
Every Time You Buckle Up In That Car, Tonight Might Be The Night That You Die.
SSFury is offline   Reply With Quote
Old 08-11-2020, 04:31 PM   #4
O.F.
O.F.'s Avatar
Drives: 2015 BLK/BLK 2SS/RS MN6
I soak my whole engine bay underhood included with Simple Green. Let it sit 5-10 minutes. Spray again the dry spots maybe. Use a sponge or rag on dirty spots if any. Spray it down with a hose avoiding the obvious intake and electrical components. I've never had a problem.
O.F. is offline   Reply With Quote
Old 08-11-2020, 04:47 PM   #5
BAD DAB
BAD DAB's Avatar
Like what was mentioned above. I use detail spray and micro fiber towels. The key is to never let the engine bay get real dirty. Wipe it down after every wash and you will be pleased with the results. Here’s a pic of my 10 year old engine bay.
Old 08-12-2020, 08:01 AM   #6
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
Originally Posted by SSFury View Post
That looks good.
Thanks sir. Yea 116k miles and is a daily 10 years old!!
Old 08-12-2020, 08:04 AM   #7
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
As DAB says above, the KEY to having a clean engine bay is to NEVER let it get dirty. Another thing is when you do use a micro and detail spray, let the engine bay cool down considerable before you do it so you don't burn yourself and the spray doesn't dry on the components and you have to do it twice. 10 year old Camaro with 116k miles on her and is a daily driver. Good luck.
Old 08-12-2020, 08:37 AM   #8
Avenging Orange
Avenging Orange's Avatar
Never get it dirty.
https://youtu.be/9JD9it6SmB8
https://youtu.be/xmelTlEzI34
Old 08-12-2020, 09:29 AM   #9
myold88
myold88's Avatar
Drives: SUMMIT WHITE 2SS/RS CAMARO
I use Simple Green with a 3" paint brush on the outer perimeter items including the shock towers and inner fenders. Then use a Light hose spray to rinse it off. It gets all the nooks and crannies clean. I then dry everything including the engine top. My SS is 11 years old now and still looks great. There's no reason to soak or rinse the engine itself.
myold88 is offline   Reply With Quote
Old 08-13-2020, 12:30 PM   #10
IOM Bullet
Drives: 2010 2SS RS LS3
Go to youtube and search for Chris fix cleaning engine bay. Great DIY. I did it 2 weeks ago.
IOM Bullet is offline   Reply With Quote
Old 08-13-2020, 02:44 PM   #11
sscamaro
sscamaro's Avatar
Drives: 2010 2SS, 2017 Silverado LTZ
My SS is 10 years old. Here is a picture of it.
2010 2SS/RS Victory Red, MN6, 1-7/8 Kooks LT Headers, SLP Axle Back, Edelbrock E-Force S/C, ZL1 Fuel Pump, 72# Injectors, JRE fuel rail upgrade, Roto-Fab CAI, Elite Catch Can, Billet Hurst Shifter, DSS 1000HP axles, Spohn Trailing Arms, Toe Links, Lower Control Arms. Chrome American Racing Torq-Thrust wheels. 546/rwhp & 522/rwtq & 10.9# boost Tune by Jeremy Formato.
sscamaro is offline   Reply With Quote
Old 08-13-2020, 04:29 PM   #12
Tajefe Couple
Tajefe Couple's Avatar
Drives: Never just fly under the radar
Just gorgeous especially at 10 years.
I have trouble cleaning around the coil packs on the holley valve covers. Any ideas appreciated!
Old Skool
Tajefe Couple is offline   Reply With Quote
Old 08-14-2020, 02:40 PM   #13
PeteD
PeteD's Avatar
Drives: 2012 2SS Victory Red with white st
Why do just the engine bay?
PeteD is offline   Reply With Quote
Old 08-14-2020, 11:44 PM   #14
wasthatacop?
wasthatacop?'s Avatar
Drives: 2010 2SS
Here's my go-to for cleaning the engine bay...
https://youtu.be/PRSoRkM8GcM
2010 2SS living in Los Angeles
replaced engine @ 93,000 miles w/ crate engine, camshaft by Comp Cams installed by me, replaced valve train parts,
1.4" BMR lowering springs
ZL1 factory rims
misc: drilled and slotted rotors, fresh air brake cooling system, new speakers, installed reverse camera, muffler delete
wasthatacop? is offline   Reply With Quote
