06-14-2020, 09:25 AM | #1 |
Drives: 2011 Chevrolet Camaro 2SS/RS Join Date: Jun 2020
Stock Ported vs Aftermarket Heads
Hey y’all,
My name is Ty and I’m new to the forum. Ive been looking, and looking, and looking on the forum at old threads discussing this (I apologize in advance if I’m opening up a can of worms) but basically I’d like to know what route y’all took for modifying your heads and why. The new heads will be going on a 2011 L99 with a TSP VVT 2.2 camshaft (227/239 113lsa .629” lift), JLT intake, and 1 7/8” headers. The goal is the biggest bang for the buck. I’d like 500rwhp but won’t be heartbroken if I don’t reach that number as boost down the road could easily fix that. Also, being my car is fat, torque under the curve is just as, if not more, important to me than peak HP. I’m on a budget and would really not like to go over $2500. Any constructive input is greatly valued! |
06-14-2020, 11:35 AM | #2 |
Drives: 2015 Camaro SS Join Date: Sep 2011
Keeping the VVT , that cam with L99 and auto you will be more around 450 rwhp ( depending on Dyno and correction factor used) If you only goal is nothing more than "500 rwhp" just save up for forced induction.
2015 Camaro 2SS Cam/Heads/FBO 498/447 SAE |
06-14-2020, 12:01 PM | #3 |
Drives: 2015 1LE Join Date: Oct 2015
The cheapest route for heads is to send you factory ones and have them ported. They wont flow as much as aftermarket but should be better. 500 rwhp on a L99 is hard to do id say set your goal to 480
2015 1LE, TSP 225/236 113+3, VMAX Throttle Body, CAI with race scoop, GPI Ported Intake, Land Speed Stage 2 Heads, 1-7/8 headers, NPP exhaust, 25% Fluidampr, LT1-S Monster Clutch, 485 RWHP & 444 TQ
06-14-2020, 02:50 PM | #4 |
Thanks for the input guys! I’ll probably look at TSP OR GPI’s porting services for the stock heads. However, I came across the GMPP heads and am considering them also since they are in my budget and I could sell my current heads. Plus I’d get hollow-stem intake valves which is a plus. I guess I’ll continue to do some more research!
06-14-2020, 02:57 PM | #5 |
If I recall the springs on those GMPP heads are only good for up to .550 lift, you will need to upgrade the springs
06-14-2020, 03:20 PM | #6 |
I will swap springs since I’m currently running the BTR dual spring
06-14-2020, 04:33 PM | #7 |
Drives: Camaro Join Date: Oct 2018
If you want to chase 500rwhp then mill them to bump compression and add flex fuel sensor and use e85
06-14-2020, 06:14 PM | #8 |
Drives: 13' 1LE Join Date: Apr 2012
Mill and light port, if any. Stock heads flow plenty to support a lot of power. The real advantage of aftermarket is extra PTV room, and the flow too. So big cam extra compression is good.
13' 1LE
Old setup: TSP 231-236/Tick 660/.105 PR, UDP, SW LT 2'' & HFC, stock NPP & H pipe, VR-DRX CAI, air scoop, Goertz1 manifold, 102mm BBK, 26" Toyo DRs, Forgestars R17x10 & F18x8, rear seat delete, remote Pat G tune Autocal, 7400 limiter, Spec Mini Twin. 91oct. 11.90@122.3, 0-60ft 2.0 / 11.99@123.6, 0-60ft 2.1 DA+819 ...519RWHP SAE Solid roller SBE LS3, FED, LLSR, 91oct, 605rwhp N/A. Tuned by Pat G. Build by me. |
06-14-2020, 06:45 PM | #9 |
I wouldn't waste your money on heads if FI is in the future plans, put that money towards saving for the FI. Stock heads flow well.
06-14-2020, 11:34 PM | #10 |
That’s a good point actually. After doing the research it would be a big chunk of change for the heads, gaskets, bolts, etc. That being said, how do you like your Whipple?
06-15-2020, 02:17 AM | #11 |
Ive ran stock ported and aftermarket heads. I gained both times.
06-15-2020, 02:18 AM | #12 |
Ported or aftermarket heads on a power adder car is just as beneficial as on a NA car.
06-15-2020, 05:29 AM | #13 | |
https://www.thompsonmotorsports.net/...cylinder-heads The second option I would consider, is the TSP 6 bolt "as cast" head. If you already have a good valvespring kit, they would cost you about $1750 for a nice set of 6 bolt heads. https://www.texas-speed.com/p-7650-p...der-heads.aspx I know you dont need 6 bolt heads now, but if you're planning forced induction, you may end up with a 6 bolt block someday, and you'll have a bad ass set of heads to clamp down and hold all the sauce. Again, thats if you have a head budget for $2500.... If not, spend it on boost. You'll get 20-30hp with just heads, or 200-300hp with boost.
2011 Camaro SS---SOLD
06-15-2020, 08:20 AM | #14 |
Thanks for the help y’all, the more info the better. I was not even aware of the Frankenstein heads and will look into those. Now I’m torn between just boosting and being done with it or doing heads now and boost later to leave no stone unturned so-to-speak. I think I’m at the point to where conservative boost would be the better route. I heard the stock heads flow pretty well up until 600-700 range before they become a choking point. Does that sound about right?
aftermarket heads, heads, ported heads |
