01-21-2019, 06:27 AM | #1 |
Drives: '23 LT1 A10 Join Date: Oct 2015
Chirping sound at highway speeds
I have a strange chirping/squeek sound that only happens at around 70+ mph. The sound does not change based off of rpm. I have downshifted and put the transmission into neutral and the sound was still there. In the video it could be hard to hear because of all the other sounds, but it drives me insane. Any ideas?
https://youtu.be/bGogyr1CYvQ
24 LT1 M6 Sharkskin Metallic
01-22-2019, 04:24 PM | #2 |
Drives: 2010 Camaro 1SS Join Date: Nov 2015
Kinda of hard to hear tbh. If it only happens at 70+ I would start looking at anything that can flap around in the wind at that speed.
01-22-2019, 07:40 PM | #3 | |
Drives: 2013 Camaro 2SS Join Date: Aug 2013
01-22-2019, 08:12 PM | #4 | |
I also ordered some header wrap to stuff along the edges of the heat shield as well. Hopefully that's it. Just a very subtle annoying noise.
01-23-2019, 06:40 AM | #5 |
Sure it isn't the well documented rear view mirror whistle that happens at 30-40, then again at 70-80 depending on the position of the mirror in the housing?
01-23-2019, 04:30 PM | #6 | |
01-24-2019, 06:42 AM | #7 |
01-24-2019, 07:39 AM | #8 |
Yeah. I'm thinking it's possibly a heat shield rubbing on the body from the excessive wind.
02-02-2019, 08:56 PM | #9 |
I pinpointed the noise to the drivers side heat shield rubbing on the floor pan.
02-03-2019, 09:04 AM | #10 |
Drives: 2015 Black rs/ss/1le Join Date: Apr 2018
Where is this spot located? I hear a creaking/chirping in stop and go traffic. It's sounds almost as if its the frame is flexing when I apply gas. It coming from around my door area and it's not the door strikers.
02-03-2019, 10:50 AM | #11 |
Drives: 2010 2SS RS LS3 Join Date: Jul 2017
It could be the styrofoam cover, over the battery in the trunk, rubbing against the steel making a chirping squeeking sound. I found that out a couple of days ago. Adjusted the styrofoam cover and chirp squeek is gone.
02-03-2019, 11:23 AM | #12 |
The heat shield that was rubbing was on the driver's side. If you look you may find it rubbing on the left side of the heat shield which would touch the "frame". I don't have a picture of the area but will try once I am able to. Look for wear marks along any part where the heat shield could touch the floor. I also wiggled the shield around and can hear a slight noise which I was able to see where it was rubbing.
02-05-2019, 05:14 PM | #13 | |
