dave@hennessey
Old 09-17-2014, 09:11 PM   #1
Chaxce
Under construction...
Chaxce's Avatar
Drives: Black 2012 2SS
425rwhp goal help
Okay so I have a stock 2012 SS LS3 which is good for 362rwhp, I want to get that number up to at least 425! I plan on doing the LS9 cam swap which they say adds 20-30hp and a Airaid CAI which is like 5-10hp so I'll be between 387hp and 402hp. I would love to keep my warranty intact so what are some other mods I can do to reach my goal? Like I said preferably keeping warranty intact...
2012 2SS/RS, mods coming soon
Chaxce is offline   Reply With Quote
Old 09-17-2014, 09:14 PM   #2
layzurguy
Ride On!!!!
layzurguy's Avatar
Drives: 2012 SS Ragtop
Exhaust
layzurguy is offline   Reply With Quote
Old 09-17-2014, 09:15 PM   #3
Chaxce
Chaxce's Avatar
Catback? What brands have the best gains?
Old 09-17-2014, 09:26 PM   #4
BenningJ
BenningJ's Avatar
Drives: 2013 AGM 1SS/RS LS3
Long tube headers (with or without cats), Ported Throttle body, an aftermarket air intake, exhaust, and tune. I have a 2013 LS3 and right now I'm sitting at 424rwhp. I wouldn't bother with the LS9 cam. It will realistically gain you about 18-20rwhp.
2013 Camaro 1SS/RS - Ashen Gray Metallic
| LS3 | CAI Inductions, Inc Intake | Vmax Ported Throttle Body | Dynatech 1.875" Long Tube Headers | Apex Scoop & Washer Bottle Relocation | Lethal Racing Night Fury Cam | BTR 7.400" Push Rods |LS2 Dampener | Melling 10296 Oil Pump | IWIS Chain | BTR .660" Dual Valve Springs | BTR Trunion Upgrade Kit | Lethal Racing Tuned | Anvil Notch Spoiler | BMR Split Drop Springs | Eaton TrueTrac | GM 3.91 Gears | LPW Diff Cover | Rohana RF2 275/40 20x10F 315/35 20x11R | BMR Polyurethane Motor Mounts
BenningJ is offline   Reply With Quote
Old 09-17-2014, 09:26 PM   #5
jc615
jc615's Avatar
Drives: Camaro and Sierra
If you're doing cam add headers as well
jc615 is offline   Reply With Quote
Old 09-17-2014, 09:27 PM   #6
Chaxce
Chaxce's Avatar
I don't believe header keep warranty? So if I ever do header it will be after I've tried all other warranty friendly items...
Old 09-17-2014, 09:28 PM   #7
62nalide
62nalide's Avatar
Drives: 2013 SS
You just want to have the number or want it to perform?
62nalide is offline   Reply With Quote
Old 09-17-2014, 09:30 PM   #8
Camero5
Hide! My wife's coming!
Camero5's Avatar
Drives: 2013 Chevrolet Camaro ZL1
Doing the CAM will void your warranty. Like the others have said, Ported TB, headers, catback, CAI and a good tune should put you easily over 400 on the LS3. If your going to do a CAM, your better off going with something with better gains. Not worth the money to go LS9 unless your doing the labor yourself.
2013 Camaro ZL1 Convertible CRT - 630 RWHP / 620 RWTQ - ADM Performance Built/Tuned - ZL-700 Package - LS9 CAM - Lingenfelter CNC Ported Heads - Stainless Power Headers
Camero5 is offline   Reply With Quote
Old 09-17-2014, 09:30 PM   #9
Chaxce
Chaxce's Avatar
Well how different does a bad 425whp perform compared to a good 425whp?
Old 09-17-2014, 09:32 PM   #10
Chaxce
Chaxce's Avatar
If I get the LS9 cam at the Chevy dealership it would keep my warranty right? If not I'll probably not get to 425 with warranty
Old 09-17-2014, 09:32 PM   #11
MightymouseSS
Drives: 2011 LS3
Only way you'll get 425rwhp is full bolt ons(cai, lt headers, ported tb, tune) and thats pushing it. The tune will void your warranty. I dynoed 400/398 with bolt ons and stock tune before getting cammed. Getting a cam will definitely get you those numbers but you pay to play if warranty is that important look into solo hf cats but you wont get anywhere near the 425 rwhp. As for the ls9 cam we'll thats gonna void your warranty as well so if your already going to go through the trouble might as well go big.
Vararam
Stainless Works Headers
Vmax TB
SLP loudmouth 2
Nightfury Cam
Mike Norris CC
Tuned by Southwest Speed
MightymouseSS is offline   Reply With Quote
Old 09-17-2014, 09:36 PM   #12
Chaxce
Chaxce's Avatar
Okay well it looks like no warranty for me, guess I'll get as far as I can on warranty friendly item then when I hit the wall I'll make the leap
Old 09-17-2014, 09:40 PM   #13
MightymouseSS
Drives: 2011 LS3
I thought the same way and ended up spending more $$$ by doing things twice. I went with jba shortys and gained hardly anything. I sold those for cheap to a buddy and got LTs and it made a huge difference. If I knew then what I know now I would've save some time and money.
Vararam
Vmax TB
SLP loudmouth 2
Nightfury Cam
Mike Norris CC
Old 09-18-2014, 06:39 AM   #14
ST1LE
ST1LE's Avatar
Drives: E92 BMW M3
Exactly this!!
Sadly there is no way around this, or we all would have found it by now.
If you want more power and want the car to 'perform', as stated above you HAVE to re-tune the ECM to calibrate it for all the changes. Sadly that is just the cold reality.
These engines have been around a long time and have proven reliability even after modded, if done right and tuned right. I appreciate your outlook though, if you cant pay to fix/replace then you should not MOD. Good luck OP, but trust me you wont regret modding if/when you do!
