10-05-2010, 07:31 AM | #1 |
Drives: 11 F150 EB/13 Sonic RS/15 Z06 Join Date: Sep 2010
Forged Pistions and Rods for LLT
Does anyone know if anyone is making aftermarket forged pistions and rods for our little V6? I've seen some stuff on the CTS that suggests it has them (http://drupal.caddyinfo.com/?q=node/44), and others that suggest they are cast like ours (http://www.zercustoms.com/news/2008-Cadillac-CTS.html). What about the Holden V6, does it even have the same bore/stroke as ours? Any guidance would be greately appreciated.
Old Ride -- 2012 Camaro 2LT/RS (647 RWHP & 726 RWTQ) -- Build Thread |
10-05-2010, 08:43 AM | #2 |
Casual Camaro Owner
Drives: 2010 Black LS V6 Join Date: Jan 2010
if they start making cams I would skip going FI all together
10-05-2010, 09:00 AM | #3 |
Red Brick of Vengeance!
Drives: 12 Second Brick Join Date: Jun 2009
This kind of stuff is going to be very labor intensive... and most likely very very expensive!
10-05-2010, 03:32 PM | #4 |
Casual Camaro Owner
10-05-2010, 04:27 PM | #5 |
Dual overhead cams with variable valve timing... basically just complicates things... requires special GM tools and then my understanding it can be PITA to time things properly and could be fairly easy to get things a bit off...
10-05-2010, 06:23 PM | #6 | |
How much are you paying and who do you use? I'm doing this because I do want turbos and I'm afraid the engine won't take much more that 6 psi with cast pistons and rods.
10-05-2010, 07:10 PM | #7 |
Retired
Drives: 2010 Camaro RS V6 #1301 DOB 3/23/09 Join Date: Aug 2009
I had no idea the cts had forged pistons. Good to know forged is available.
10-05-2010, 07:13 PM | #8 |
I'm saying one place I looked said it did, the other one make it sound like it had the same as ours.
10-05-2010, 07:49 PM | #9 | |
Drives: White M6 1LT RS Join Date: Mar 2010
Not trying to be a smartass but says who?
Pfadt Sway Bars - FE3 Suspension - Barton Shifter - IdealG's Clutch Master Cylinder - Trifecta - Vmax TB - Vararam Intake - MACE 25mm Insulator - Plenum Insulator - Ported/Gasket Matched Intake Manifold - Rx Catchcan - AAC DRL's - 4 Pack Aux Gauges - Steering Controls - AAC Afterburners - DIY Led Sidemarkers - ZL1 Front End
Next mod: Done! |
10-05-2010, 08:45 PM | #10 |
Casual Camaro Owner
10-05-2010, 08:56 PM | #11 | |
Drives: Really Slow Join Date: Apr 2010
10-06-2010, 07:16 AM | #12 | |
I also think similar issues may arise with the tranny. I don't know it as fact, but if you look at the specs on the Wiki site you'll see the max tq. is pretty low (332 ft-lbs for A6, 345 ft-lbs for M6). So, if assume 500 HP with 6 psi (I think that is what STS is claiming) at 6500 RPM, you are generating about 400 ft-lbs torque. You might be able to push it that far because the transmission is rated at that for a 5000 lb vehicle and because you won't be putting that out right away, but turbos do put out a lot of torque at low RPMs (especially small ones). Of course, I won't know until I get the turbos and do the dyno.
10-06-2010, 08:39 AM | #13 | |
That being said... a properly tuned automatic should be able to handle a bit more than what it's really rated for... you might not get 100,000 miles out of it... but I would think it would hold up pretty well... key is going to be getting the tranny calibration correct and changing the fluid a lot more often than the book says...
10-06-2010, 08:54 AM | #14 | ||
400 I'm not too worried about. Vince can tune it up to a point. However, I'm not sure it can handle the TQ you would be throwing at it with say 10-12 psi. Even if the TM system can accomodate it at low RPM it will do it at the expense of the launch I would think. I'd rather build the tranny and throw the power at it . Just my idea for my car -- others may have other opinons.
