06-10-2012, 10:59 PM | #1 |
Drives: 1987 Corvette TPI Join Date: Mar 2012
Need help, she won't start without gas!
I have a 1987 Corvette, went to a spray n wash. Just sprayed the whole car down to get off the dirt, sprayed the tires, wheels, and wheel wells. And went to pull her out, she won't start without the foot on the gas. So I said screw drying her off I have to get her home before she croaks for good! Now she is in the middle of the garage and won't start unless foot on gas still. I went to try her again after drying out for two days. Won't start smokes a tiny bit, but if you have foot a little on gas she is good! Help me please!
06-10-2012, 11:14 PM | #2 |
it never happened on my camaro///but my maxima did this..exactly this///my ecm was bad...everytime i started her i had to keep my foot on the gass....and i couldnt keep my foot off the gass at all or the car would stall
top 10 reason why real men drive stick. 10. A manual transmission is the ultimate in control 9. You can use automotive jargon and not sound like a total tool 8. You can't spell "manual" without "man" 7. Manual transmissions prove you can do more than one thing at a time 6. You can't drift in an auto 5. You can't pull fancy moves in an automatic 4. You get better fuel economy with a stick 3. You’ll never look like a chump if you can drive stick 2. Manual transmission cars are faster 1. Women like a guy who is good with his hands. |
06-10-2012, 11:17 PM | #3 |
Boosted Moderator
I'll have to check with Corey in the mo0rning, which I will do, but help me out a little bit.
It could be a shorted connector for the TPS, throttle position sensor, the Cold Start Switch, or the cold start fuel injectors. Check each of these and maybe unplug them and replug them in... Beyond that, I'll have to quiz Corey and will probably show him this thread... Sorry I can't help more...
Horsepower is how fast you hit the wall. Torque is how far you take the wall with you. “If everything seems under control, you're just not going fast enough.” Mario Andretti If you can turn, you ain't going fast enough... |
06-10-2012, 11:42 PM | #4 |
Drives: 2010 Camaro SS,2008 Hayabusa Join Date: Jun 2010
Are you getting a CEL. It could be a few things, bad injector,fuel pressure regulator,injector fuses or maybe a mass air sensor.
06-10-2012, 11:56 PM | #5 |
Absolutely no new lights on.
06-11-2012, 09:18 AM | #6 |
I checked what you guys said except for the ECM, took it to Mike Ward Infiniti where I bought it to have it checked out and a quote. If it's too difficult I'll let Scott(Covette Specialist) over there fix it.
06-11-2012, 10:44 AM | #7 |
Drives: 2012 Camaro RS, RX supercharged Join Date: Dec 2009
Two things point to the brittle vacuum lines by the battery area. I suspect the high pressure spray hit a vacuum line (all C4's will have brittle crumbing lines by now) so you have created a vacuum leak. Follow all from the distribution links aroundthe battery area, and along the IM. Your AC will not operate the vent diverters and you will not idle due to the vacuum leak.
Let us know what you find....all the lines need to be replaced as they all crumble when that age. |
06-11-2012, 01:46 PM | #8 |
Thank you all so much! I went over and talked to Scott for a bit, he said ECM was fine, and one of the vacuum lines was practically clean cut. Which makes sense why my A/C sucks! And he cleaned out the distributor with air compressor I'm so happy to have her back!
