TireRack
Old 05-25-2011, 09:41 PM   #29
Camarowguy
Camarowguy's Avatar
Drives: 2011 imperial blue SS, black 92 RS
I'll check it and see
2011 imperial blue SS/RS a6 12.43@112 vararam, tune, jba cats, magnaflow axle back, self ported tb, under drive pulley, NO headers, Stock tires. 1.87 60ft. Stock tires. SOLD :(
2000 1500 silverado extra cab SOLD :(
2017 Silverado 5.3 all stock
2004 5.7 GTO 78mm turbo
Camarowguy is offline   Reply With Quote
Old 05-25-2011, 10:01 PM   #30
TheColorBlack
Drives: Black 2011 LS
I dont know...but I just put the rubber piece in and it stop the noise for me as well and it cost less than 10 dollar and less than 10 min of my time.
TheColorBlack is offline   Reply With Quote
Old 05-26-2011, 12:53 AM   #31
TAG UR IT
www.Camaro5store.com
TAG UR IT's Avatar
Drives: 2014 ZL1 #705
Guess what I tried today...lol
Old 05-26-2011, 05:02 AM   #32
Rob@WretchedMS
Drives: His Wife Crazy
lol
Rob@WretchedMS is offline   Reply With Quote
Old 05-26-2011, 07:20 AM   #33
ADIO SS
ADIO SS's Avatar
Drives: 2010 White SS/RS L99
Had the LF strut replaced - no more noise - a miracle as no one could explain why and GM thinks this is not a problem. Normal as I was told...
ADIO SS is offline   Reply With Quote
Old 05-26-2011, 03:47 PM   #34
JusticePete
JusticePete's Avatar
Drives: Camaro Justice
There are two sources of noise in the OE strut assembly.
1. Is a flutter in the hydraulics of the OE damper. The damper works perfectly, but there is a noise caused by the valve action. It is very slight. There has been a running change made to eliminate it.
2. The rubber insulator that was used for about the first year of production could 'walk' out of place. The partially in partially out condition could create a click under certain conditions. When installing Pedders coilovers we simply discard it, but it should be used with OE or lowering coils. The updated insulator is a stamped steel and urethane bit. If I didn't know better I would say it was designed at Pedders. We have successfully eliminated strut noises by installing the new steel and urethane insulator shown on the right in the image below.
If you are wondering which one is on your 5th Gen, grab a flashlight and look up into the wheel well where the spring meet the upper perch. If the exposed ring is beige, you have the new one. If the ring is black you have the old one.
There is no TSB on this. It is one of many running changes being constantly made to improve the 5th Gen.
Old 05-26-2011, 03:48 PM   #35
JusticePete
And now you know...
Old 05-26-2011, 04:22 PM   #36
BMR guy
BMR guy's Avatar
Drives: 2010 1SS
The 4th gen guys over on LS1 Tech have names for all of the typical low cost mods they do (heater hose mod, etc.). I can see this turning into the toilet mod or something equally funny
BMR guy is offline   Reply With Quote
Old 05-26-2011, 04:47 PM   #37
wlee32
Drives: 2011 2LT Blk/Orange Strip & int
+1 for a very loud noise and feeling like something broke when going over some bumps...
2011 Black 2LT with Orange Stripes and Interior;
35% Tint All Around, light tint on windshield;
Razzi Ground Effects Kit;
AAC P13 LED DRL bulbs (DRL Harness);
AAC Colorshift Halos for Main and DRLs;
Amber AAC Footwell Lighting;
LED Dome and Trunk Lights;
Triple 10" P3s, ******** Front Firing Box;
Magnaflow Street Series Catback;
Barton Short Throw Shifter.
wlee32 is offline   Reply With Quote
Old 05-26-2011, 04:48 PM   #38
wlee32
on the front.
Old 05-26-2011, 04:49 PM   #39
JusticePete
Originally Posted by wlee32 View Post
on the front.
Yes only the fronts.
Old 05-26-2011, 07:14 PM   #40
ssmike
BL1ZZRD
ssmike's Avatar
Drives: '16 Camaro 2SS, '20 Equinox Redline
Originally Posted by axis View Post
I too developed the "clunking" noise when puling into my driveway or going up a slight incline. It just happened one day and for no apparent reason. Checked everything and made sure everything was tight. Took it to my friends tire shop and they found nothing as well. I have had the Pfadt springs and sways for about 6-8mo with zero issues. I went ahead and bought the endlinks, thinking it could be them going out, even though my car only has 14k miles on it. Guess what, it's fixed my problem. Absolutely ZERO clunking now. Not saying this is your problem, but it's a possibility. Personally, I wouldn't fill in the gap.
What endlinks did you use? I have BMR's and they are starting to make noise. I re-torqued and I'm confident everything is tight.
ssmike is offline   Reply With Quote
Old 05-26-2011, 07:22 PM   #41
axis
Search Ninja
axis's Avatar
Drives: 2010 Black 2SS/RS A6
I got the Pfadt ones.
BTW: I think Chase is the only one that has them right now. Pfadt is going to run another batch soon though.
Halltech CF 102 fed
GPI modded intake manifold
Bo (knows) White ported TB
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
Dyno tuned by Rhino and GPI
I once parallel parked a train.
axis is offline   Reply With Quote
Old 05-26-2011, 07:35 PM   #42
YOUNGnRECKLESS
Building the Beast
YOUNGnRECKLESS's Avatar
Drives: 2010 VR LS3
play, so quick question...can it happen at all in the rears? I have a rattling noise coming from my right rear wheel well on any bump, very metal on metal embarrassing noise...im not driving it till i find the problem. tried tightening various things but after a week...still much rattle. it sounds like metal on metal...
YOUNGnRECKLESS is offline   Reply With Quote
ZL1 / CTS-V Brakes JusticePete Suspension / Brakes / Chassis 584 10-14-2021 09:33 AM
Poll -- Camaro vs Mustang Supercar Shootout JusticePete Suspension / Brakes / Chassis 105 10-09-2013 02:18 PM
Got Pulled over... TRSS2 Cosmetics and Lighting Modification Discussions 39 03-08-2010 11:57 AM
2010 Camaro SS Blue in Syracuse NY $32690 Mitsubishi in Syracuse Camaro Price | Ordering | Tracking | Dealers Discussions 0 12-31-2009 02:44 PM
2010 Blue SS for $32990 and we pay for your plane ticket! Mitsubishi in Syracuse Dealer Camaros for Sale 0 12-21-2009 12:42 PM
