10-07-2020, 12:52 AM | #1 |
Drives: Supercharged 2013 AGM 2SS/RS Join Date: Oct 2013
Battery keeps dying...
Hi everyone,
Having some problems with my battery draining. Normally was driving the car everyday, but now that I’m working from home and only driving it about once a week I seem to be having a problem. If the car sits there for 5-6 days, I’ll try to start it and it’ll crank a bit but not start. If I boost with a battery pack it starts. So now I’m plugging it in for a few hours once a week with a battery charger and it’s ok, but that doesn’t seem sustainable. Battery is only about 5 months old. I used my multimeter to check the parasitic load. With the car off I got a power draw of 6 amps, which seems crazy high. I went through a pulled each of the fuses to see where it’s coming from. Seems most of it is coming from the Radio fuse, some from the Air Conditioner fuse, and a little from the Battery fuse. That’s about the end of my mechanic skills. Any suggestions on what to do? Do I need to replace my stereo and AC? Thanks for any help. HAMBO
2013 AGM 2SS/RS
SLP TVS2300, Edge CAI, 3" Magnaflow catback, BC Racing BR series coilovers, HRE FF15's (20x10 square) with Michelin Pilot Sport 4S's, GM STB, BMR front and rear sway bars and toe links, Prothane subframe bushings and front control arm inserts, JDP rear upper control arm bushings, Elite Engineering catch can. Tuned by Cunningham Motorsports. 1967 Bolero Red 396 SS/RS Convertible |
10-07-2020, 06:17 AM | #2 |
Drives: 2014 1SS/1LE Join Date: Nov 2015
6 amp parasitic draw is insane
Sent from my Pixel XL using Tapatalk
10-07-2020, 08:02 AM | #3 |
Is your stereo aftermarket or stock? Has any part of your stereo system been “messed” with. Does your stereo turn off if engine is off and drivers door is opened? Try testing draw before you open the drivers door and then after opening it, seeing if the draw drops after the system is suppose to shut off. Try disconnecting each piece then see what draw is. Amp, head unit, etc. once you get it isolated to a specific device then look at wiring to that device, pinched wire causing hot wire voltage to ground, hence draining battery. It might just as easily be a circuit board inside your stereo or amp.
Troubleshooting this type of issue can get tedious and $$ if you pay the dealer to chase it. Good luck and sometimes it’s an easy find and you get lucky. |
10-07-2020, 09:07 AM | #4 |
Thanks. It’s the stock, Boston Acoustics stereo
2013 AGM 2SS/RS
10-07-2020, 09:42 AM | #5 |
10-07-2020, 11:37 AM | #6 | |
Drives: chevrolet camaro Join Date: Mar 2020
Yeah, I would recommend that same. This problem must be so annoying for you! Last edited by jimrhodes; 10-26-2020 at 02:51 AM. |
10-07-2020, 12:20 PM | #7 | |
Would like to bring it in for service, I'm just worried something like this could take countless hours to properly solve and be very expensive...
2013 AGM 2SS/RS
10-07-2020, 12:21 PM | #8 |
I couldn't believe it when I saw it either...maybe (was actually hoping) my multimeter was broken!
2013 AGM 2SS/RS
