09-20-2015, 08:30 PM | #1 |
Jan
Drives: 2010 Camaro 1LT Red Jewel tintcoat Join Date: May 2010
Help for hard water
Okay, our water has always been terrible for making water spots but it must be getting worse. I know a lot of it is lime (limestone) and some iron (from our infamous red clay dirt); not sure what else. No matter how fast you go or how you wash, water spots are just awful. Is there any kind of a filtration system you can hook up to your water hose to take some of that crap out? I tried searching on ebay but clearly I am not entering the right search words to pull it up if such a thing exists and if it doesn't someone needs to invent one!
09-20-2015, 08:37 PM | #2 |
Drives: 2013 ZL1 M6 Join Date: Oct 2013
Here you go Ruby check this system out.
http://www.autogeek.net/deluxe-filter-system.html You can also add rinseless wash solution to your soap bucket to aid as a water softener. http://www.autogeek.net/optimum-no-rinse.html Hope these links help. Norcal |
09-20-2015, 08:52 PM | #3 |
Jan
Thanks. Dang, that water filtration system looks complicated.
09-20-2015, 10:31 PM | #4 | |
Drives: Love the one you're with Join Date: Sep 2009
Good luck! |
09-20-2015, 10:45 PM | #5 | |
As an alternative you can just go water less and use de-mineralized water as your water for the concentrate mix. I use water less wash about 90% of the time and it works great. I use this kit and only use the hose for rinse less washes to fill two buckets. I love this water less wash, super fast, excellent results. http://www.autogeek.net/waterless-car-wash-kit1.html |
09-20-2015, 10:51 PM | #6 | |
Cool! |
09-20-2015, 11:01 PM | #7 |
TX SS
Hague water max is what you need. I own a plumbing and water treatment company!
09-20-2015, 11:16 PM | #8 | |
This is another reason I have converted to water less washes as our city water here is at 600us on the meter, I have to test the TDS some time. |
09-20-2015, 11:24 PM | #9 |
Interesting, no salt. We have some pulsed humidifiers that use a bead media to soften the water that works pretty well. No scale what so ever. The media does need to be changed out when the water quality exceeded 6 ppm. Is this the same kind of media?
09-21-2015, 08:37 AM | #10 |
Oldbie that nobody knows
The CR Spotless Deionization system is probably the mainstay water filtration system manufactured solely to wash cars with spot free water. Here's a link to the medium output version: http://www.autogeek.net/cr-spotless-...FQUGaQodNxYPvw
It's good for around 100 gallons, which is around two month's of weekly washes; more if you conserve it and only use it as a last step rinse, less if you waste a lot of water. They have a higher output version, but it's more expensive. If your water is as bad as you say it is, the resin will wear out quicker as well, meaning you'll need to replace it more frequently. One way to avoid water spots without breaking the bank on filtration systems is to only wash your car when the sun isn't out and when the ambient temperature is lower. You'll have all the time in the world to dry to a spot free finish if you wash your car in late noon / early evening or in the early morning. That's how I avoid water spots, and my water is abysmal like yours. |
09-21-2015, 09:32 AM | #11 |
Drives: 2011 2SS/RS Join Date: Feb 2014
another thing that I've found REALLY helps with the spotting is to wash early in the a.m while still in the shade.
Hot paint will dry up your soapy water mix, or even your rinse water, and spot before you can touch it with a towel....at least that's been my experience with a black car in this TX heat... |
09-21-2015, 03:12 PM | #12 | |
Drives: Replacement 2SS 'Vert 67 Cutlass Join Date: Aug 2015
http://www.purewaterproducts.com/garden-hose-filters Tim |
09-22-2015, 06:02 AM | #13 |
Jan
Thanks guys. All good info.
09-22-2015, 06:08 PM | #14 |
Drives: The shiny ones. Join Date: Mar 2010
Adam's Shampoo is PH balanced so while you are washing it is way safer to leave all the soap on the entire car before rinsing. After the car is all washed, rinse the car off. Before drying, spray Adams Detail Spray on the entire car then proceed to dry.... this too will help with water spotting.
As far as the water spots that you all ready have, they will polish out with our Paint Correcting Polish & Orange Gen5 pad. PM me if you have any questions! http://adamspolishes.com/video?video_id=22 http://adamspolishes.com/video?video_id=15 |
