06-29-2022, 12:07 AM | #1 |
stroker gas mileage
Hey guys so I'm thinking that I'm getting ready to do a full rebuild pretty soon and was thinking of going with a 415 stroker and was wondering if the gas mileage will go out the window? And I think I might go with the GPI SS3 vvt with around a 3200-3600 stall converter but not sure I might just go with a small enough cam to run the stock converter like my current SS1 but I will be doing a tranny rebuild as well.
06-29-2022, 02:12 AM | #2 |
Runs on caffeine
Drives: 2010 Camaro SS Join Date: Apr 2020
I have been curious about running a cam meant for an LS3 with a stroker kit. I'd assume cam profiles will be different for the duration as the intake and exhaust strokes are longer (in distance, not time).
06-29-2022, 06:10 AM | #3 | |
Drives: 13 CAMARO 2SS LS3-04 SILVERADO LS3 Join Date: Dec 2021
06-29-2022, 09:33 AM | #4 |
I don't have a 415 stroker, but I reall love my 4500 stall with my build! Went from a 3200 which wasn't quite big enough.
06-29-2022, 09:33 AM | #5 |
Big Crow
Drives: '13 ZL1 Join Date: Mar 2017
I think the cam choice will be the biggest loss or gain in mpg. Yeah some losses too from slipping converter depending on how much time you spend driving without it locked, e.g. city.
The bigger stroker causes more friction and pumping losses. Change the rear gears to 3.91s or 4.11s and add some high rolling resistance big sticky tires to help further the fun and mpg loss. Edit: It's interesting the mpg of an SS vs ZL1 with the same type car. The ZL1s get sht mpg even stock. The blower doesn't add more than a few hp of frictional drag due to the bypass. I'd guess the high hp capacity trans and diff and some friction. It has a tiny cam. Maybe no VVT hurts it more than I expected too. The LS3 doesn't have VVT but mpg isn't bad also. |
06-29-2022, 09:48 AM | #6 | |
07-04-2022, 11:15 AM | #7 |
So I think I'm going to stick with the stock displacement just for the sake of gas mileage because right now I get 20 mpg on the highway. But I will be going with a little bigger cam and maybe a converter so I'm sure that will suck a little more mileage out but hopefully not too much.
07-04-2022, 12:01 PM | #8 | |
Drives: 2013 SS/RS, 2015 Camaro SS/RS Vert Join Date: Sep 2019
07-04-2022, 02:50 PM | #9 |
Drives: 2013 2SS/RS Convertible Join Date: Apr 2016
I get 8.7mpg on E85.
07-04-2022, 07:39 PM | #10 |
Dan
Drives: 2010 Camaro 2SS IOM Join Date: Nov 2013
I average 10.5mpg supercharged on E85. But this is my baby, not my DD or truck. Also E85 is still cheaper hear than 87 so I say screw it...
Dan
2010 IOM SS YSI-B, Pat G Cam, Ported CTS-V Heads, ARH LTs MBRP 3" exhaust http://www.camaro5.com/forums/showth...&highlight=ysi |
07-04-2022, 08:26 PM | #11 | |
07-05-2022, 07:11 AM | #12 |
Well with my build I'm getting 21.3-22.0 on the interstate cruising at 72 mph, about 1800-2000 rpm, around town I drive in manual mode with the converter locked and am getting about 14-15 mpg, in sport with it unlocked around 12-13. Like I have said before on the forum, my tuner said he has my trans tune set up for what he called "manual auto lock", so whenever I go to manual mode, it locks the converter, this way also I am able to keep the trans cooler too by it not slipping. Really nice aspect. I drive her just like a stick car, tons of fun and sounds great shifting up and down. On the highway we have it set to lockup at 55 mph.
07-05-2022, 06:53 PM | #13 |
Tri-County Camaro SWFL
At 80MPH I get about 15.5. City is 10.5/11.5 on E. 513 wheel, NA
07-05-2022, 07:20 PM | #14 |
Omg are you serious? That absolutely sucks. Are you tuned or anything?
