Go Back   CAMARO6 > Engine | Drivetrain | Powertrain Technical Discussions > Transmissions
AWE Tuning
Old 05-22-2021, 12:40 PM   #1
02blackss
02blackss's Avatar
Drives: 2023 ZL1 Convertible
620 Miles, Transmission leak, 2021 LT1 MN6
So, I have had the car about 2 months now. 6-Speed manual...started noticing a few drips in the driveway under the centre of the car. Got my trusty old mirror and took a look. Sure enough, transmission fluid pooling in a few spots at the lowest points of the transmission. The Tranny support bracket IS bone dry however. It will not leak if it just sits there....Only leaks after it has been driven, then parked kinda thing. I wiped it off last week, let the car sit a week and not a single drop. Wherever its coming from, its small, but it's at the dealer right now, wont be looked at until Tuesday as its a holiday here Monday in Canada......Total piss off.... I have been pretty gentle on her since I got it, no abuse on my end...
Jason
2022 Equinox RS
2023 Trailblazer RS
02blackss is offline   Reply With Quote
Old 05-25-2021, 01:58 PM   #2
02blackss
02blackss's Avatar
For those who care, it turns out the fill plug was barely tightened...The transmission mechanic said it was only threaded in by "about 2 threads" He says he has never seen one that loose before. He was actually able to unscrew it with his hand. They cleaned everything up, took it for a test drive, will let it sit overnight and do one more check tomorrow to see if anything drips down.
Cheers,
Jason
2022 Equinox RS
2023 Trailblazer RS
Old 05-25-2021, 05:54 PM   #3
Scottyz
2019 ZL1 1LE MY GOON
Scottyz's Avatar
Drives: 1980 Z28 Big Red.
Why does that sound familiar????
Scottyz is offline   Reply With Quote
Old 05-25-2021, 06:58 PM   #4
02blackss
02blackss's Avatar
LOL
Thanks man
2022 Equinox RS
2023 Trailblazer RS
Old 07-10-2021, 10:50 PM   #5
Ventmaster
Ventmaster's Avatar
Drives: 2017 1SS 6spd
Glad it wasn't something more serious Scott. Likely just slightly over-filled that expanded when it got hot and gave you some drips. Unlike the the 5th Gen, they want you to under fill the manual rans by 1/16th inch in the new ones. if you change the manual trans fluid, then pull off 1/16th inch fluid at operating temperature for optimal performance (I think- double check me, the web site was down when I was stealing this info.
Ventmaster is offline   Reply With Quote
