11-28-2021, 07:59 AM | #1 |
Black lightning
ZLE OWNERS
Do The ZLEs have the the same heat stroke issue as the regular ZL1s with the additional 10 heating elements etc?
[ 2021 Camaro ZLE 10 speed
11-28-2021, 08:16 AM | #2 |
Drives: '22 Summit White ZL1 A10 Join Date: Aug 2019
The "11" heat exchangers are on both model ZL1's......
Are you speaking of the heat soak issues that the early LT4 Z06's had going into limp mode? This wasn't an issue with the ZL1. |
11-28-2021, 08:17 AM | #3 |
Sarcasm loading --------
I havent had any issues at the track, but my car is stock.
Ive read posts here that say if you modify you have issues with heat, but I have not read any posts where someone actually said they have issues with heat after modification.
"The salesman actually told me to stop getting it sideways during the test drive"
2018 MBM ZL1 1LE - Stock 2014 CRT ZL1 574 rwhp, 537 rwtq - SOLD 2010 IBM SS Camaro VVT L99 w/ TR6060 swap, 489 rwhp, 444 rwtq - SOLD |
11-28-2021, 08:22 AM | #4 |
Drives: ZL1 1LE on order Join Date: Nov 2021
Even though I’m still waiting for mine I’m sure the others will chime in.
Depends on how critical you’re trying to be. Stock car limp mode doesn’t seem to be an issue from what I’ve read. Like nighttowl said mostly heavily modded cars are more at risk of heat soak. BUT others have said just due to the physics involved even a stock car will start to pull power if it’s really hot and you’ve been sitting in traffic until you can get the air moving against the coolers again. |
11-28-2021, 08:38 AM | #5 |
Drives: 2021 ZL1 1LE Join Date: Aug 2010
My ZLE is stock and during the 26 track days I only had one time the car started pulling power. VIR 97 degrees outside after 40 mins running the shit of the car on the back straight it started pulling power. No other issues all year.
11-28-2021, 08:48 AM | #6 |
Drives: 2020 Zl1 A10 Riverside Blue Join Date: Mar 2020
So I know your asking ZLE owners but snice the cooling is the same for both models I'll chime in. I run at the track for 25mi sessions at time with no problem. I do have the 125 package from Jannetty so im not stock. I did have an issue one time due to the fact that the thermostat was not working and I over heated and the trans fluid got super hot.
11-28-2021, 08:50 AM | #7 | |
Black lightning
Exchangers. I thought it was an Zle thing for track purposes
11-28-2021, 08:52 AM | #8 | |
Black lightning
11-28-2021, 08:53 AM | #9 |
Black lightning
Damn!
11-28-2021, 08:54 AM | #10 | |
Black lightning
I had no idea thanks
11-28-2021, 09:49 AM | #11 |
Drives: Garnet Red / ZL1 1LE Join Date: Apr 2016
ZLE owner here that has tracked actively. No heat soak issues to date - I have pounded the car at VIR in Ambient Temps of 96' with 80%+ humidity. The car never skipped a beat.
The only thing I have as an 'engine mod' is the ADM V2 LT4 Reservoir.
#SAVETHEMANUALS
11-28-2021, 10:37 AM | #12 |
Drives: 2019 Chevy Camaro ZL1 M6 Join Date: Jul 2019
Keep the car on stock pulleys and there really isn’t an issue with heat soak unless you get into extreme conditions.
Kong Stage X Port, NW103, LPE HPFP, XDI +30 Injectors, ARH Headers, Flex Fuel, JMS Booster, AWE Touring, Elite E2-X CC. Stock heads, stock cam, stock pulleys: Tuned by KingLT1. 740whp Uncorrected on e50
11-28-2021, 03:54 PM | #13 |
Black lightning
Is it the same with 1/4 mile runs, I always here the heat soak issues regarding slip times
11-28-2021, 03:58 PM | #14 |
Most people who drag race these cars install smaller pulleys and then yes, there will be heat soak issues
