10-21-2016, 10:05 AM | #1 |
Drives: 2016 Chevy Camaro SS Join Date: Feb 2016
Cam install
I just read on a different site that a cam install cannot be done without removing the engine. Is that correct?
10-21-2016, 11:05 AM | #2 |
Drives: 16 2SS 6MT NPP MRC / 15 K1300S Join Date: Mar 2016
I'm iffy on this but I believe it was specifically oil pan removal that was required?
Rohana RFX-5 10/11, M/T 275/305, Eibachs, Hellwigs, Hurst SS, DMS LT4 SC 596HP/589TQ, DMS Low-side, Kooks 2LTs, MBRP Race, Rotofab, MMS CC |
10-21-2016, 11:59 AM | #3 |
Drives: 2016 Bright Yellow 2SS A8 Join Date: Jul 2014
I believe it's because the LT1 oil pan and timing cover does not utilize gaskets like the the LS engines. RTV silicone sealant is used. The dry-sump pan needs to be dropped to remove the cam phaser gear and timing chain. It's going to be expensive to drop a cam in these things.
10-22-2016, 06:24 AM | #4 | |
10-22-2016, 08:29 AM | #5 |
Drives: SS 6 speed of course Join Date: Jan 2016
http://www.superchevy.com/how-to/eng...-lt1-cam-swap/
The pump sits in front of the timing gear, the Camaro is wet sump. It is not crazy hard, but yep harder than a LS engine which was candy.
10-22-2016, 09:29 AM | #6 |
Drives: 2016 Camaro 1SS M6 Join Date: Sep 2016
You could just lift the wngine using a sling or hoist to gain the required clearance instead of completely removing it.
10-22-2016, 12:18 PM | #7 |
Drives: 18 Silverado 1500 Join Date: Dec 2015
Pricing on cam installs in the LT1 has been discussed before, but if you are going to have a shop do this install, it might make more sense to go with a supercharger for the money and amount of power you'd get.
If you do the install yourself (because you have the tools, engine hoist, and garage), cam is still a good option. It isn't a one day, drink some beers with your buddies job anymore.
16 Red Hot 2SS A8: NPP, CAI Cold air, Ported TB, Fasterproms Ported intake, E85 flex, Formatto tuned. 11.80@118 with 1.92 60' (600-700 DA) on stock run flats.
10-22-2016, 12:26 PM | #8 | |
But that lopey idle sure is nice...
10-22-2016, 07:53 PM | #9 |
Drives: C7 Z06 manual, 18 Zl1 manual, etc Join Date: Dec 2013
no sir you don't have to remove the engine for cam install on lt1 lol. The shop that is doing mine already did 2 so far without dropping the engine
10-27-2016, 10:21 PM | #10 |
Drives: 2016 2SS coupe 2015 3LT Stingray Join Date: Aug 2012
Dont know if Southwest speed is on here he was a vendor on c5 but he has done several Ill see if Incan get him to chime in
Ported intake manifold and throttle body kooks 2" headers no cats
09-13-2017, 03:52 PM | #11 | |
Drives: Me: '16 2SS yellow, Wife: '16 1SS Join Date: Feb 2016
- Dennis Hixson
2016 Camaro 2SS ** EdelBrock E-Force Supercharger, 3" pulley, RotoFab air intake, Alky Methanol Injection System, Corsa Extreme Exhaust, Kooks longtube headers, TSP VV2 CAM, 1LE wheels @ 285/30/20 front & 305/30/20 rear... 707.41rwhp, 702.36 torque |
09-13-2017, 04:00 PM | #12 | |
SABIO
Drives: 2016 CAMARO 1SS Join Date: Jul 2015
I paid double the amount for parts than I did labor. Haha
09-13-2017, 04:12 PM | #13 |
Drives: 2017 SS 1LE Mosiac Black Join Date: Nov 2016
There are pluses and minuses with either approach, but yes, a cam can be installed without pulling the engine, although pulling out the radiator and dropping/resealing the pan can be a challenge.
09-13-2017, 04:25 PM | #14 |
Drives: 2016 2SS Join Date: Jul 2016
My cam job will be starting on Saturday. I think I am just going to pull the motor. But mine is going to be a bit involved so I it is best for me to pull it. I don't plan on losing any torque, anywhere. I have a buddy that has done a bunch of cam swaps and he has decided to pull the motors. He did it both ways and according to him, it is just faster.
2016 2SS. H/C SBE 1.37 60ft, 6.36@109.49, 9.97@136+. Nuff Said.
