09-13-2017, 07:16 PM | #15 |
Drives: 2017 Camaro 2SS Join Date: Mar 2017
I have made the decision to do a cam swap as well and have been ingesting so much info. I think I will be going with the engine pull method. I've done other projects that involved pulling the pan while in the vehicle and it's too difficult to get things sealed back up in my experience. I'll be doing supporting mods this winter and cam next winter but inintend to document the entire process for the forum.
2017 NGM 2SS NPP M6 MRC Vortech SC, 2" TSP LT No Cats, Borla X, Eibach, Hurst shifter 603hp/547tq |
09-13-2017, 09:57 PM | #16 | |
2016 NFG 1SS A8
09-14-2017, 04:39 AM | #17 |
Drives: 2016 2SS Join Date: Jul 2016
Not right now. Possibly when the blower goes on. But someone needs to make a piston that we can safely get to 13.0 SCR. Almost all of these cams coming out need at least 12.6 SCR just get back to stock DCR. I fully believe that is why we are seeing the aftermarket cams not make much of any tq and start to get gains around 5K. Since there is no PTV in these cars you are very limited to when the valve events can start. I am going to take a bunch of measurements this weekend to figure out what can be done on the cam front.
2016 2SS. H/C SBE 1.37 60ft, 6.36@109.49, 9.97@136+. Nuff Said.
09-14-2017, 06:31 AM | #18 | |
Drives: 2017 SS 1LE Mosiac Black Join Date: Nov 2016
09-14-2017, 06:43 AM | #19 |
Shifts under load
Drives: 2020 Camaro 1SS 1LE rally green Join Date: Apr 2017
I definitely miss the LSX cam swapped cars I had, but wow do these drive so much better.
24 Audi S3 prem plus, sport package
HPDE - southeast - JTI- solo, PCA- blue. 22 Suzuki GSX-S 1000GT blue |
09-14-2017, 06:45 AM | #20 |
Almost all of the aftermarket cams lose at least 1 full point of DCR. That is substantial. Especially if you are going to run E. E loses it's effectiveness as compression goes down. Going from a IVC of 29* with the stock cam to a IVC or around 44* with most of the aftermarket cams I have seen is a killer. When you go to some of these STGIII cams out there you are killing yourself unless you have at least a 4C (probably need a 5C) and plan on shifting the car at 7,500. I am sure it looks good on the dyno but I bet it doesn't get down the track.
09-14-2017, 07:36 AM | #21 | |
That is why I kept my Fbody...6g is a better but I still love my H/C LS6 hard top.
2016 NFG 1SS A8
09-14-2017, 07:49 AM | #22 |
SABIO
Drives: 2016 CAMARO 1SS Join Date: Jul 2015
Figuring out the right combo is the hard part.
I managed a 40ft/lb gain w/ +70ft/lbs @6000rpm. But I did heads as well. I guess it is how much gain you expect as reasonable.
09-14-2017, 08:37 AM | #23 |
Shifts under load
The cost per hp really comes into play too. Sounds like you're way better off going FI and maybe someone will come up with a ghost cam tune so you have the best off both....
09-14-2017, 11:40 AM | #24 |
Drives: 2017 Chevrolet Camaro SS 1LE Join Date: Jul 2017
Can you combine lower compression pistons with a higher compression head to recover some of the cam loss? E.g. CMS 10/5/1 pistons/rod drops in with Lingenfelter 12/1 cylinder heads.
09-14-2017, 11:59 AM | #25 | |
I think the other big deal is that most of these cam offerings are on a 114-116 lobe sep. That alone is going to mover your power band up and move your IVC way back as well. A double whammy really. What I am very curious about is to see what the PTV for the exhaust is. I personally don't spec any cams save one, on anything over 112. Most of my cams are 110-111. If you get your over lap right you can maximize DCR and the tq curve with a very strong top end. I just sent off a ported top end package with a custom cam today. We will see how that does in a couple weeks. I will have a lot more answers by Sunday with my stuff. If for some reason I run into issues I can't over come to run the cam I designed for my car then I will throw in the blower cam and throw the blower on.
09-14-2017, 01:28 PM | #26 |
Drives: 14 Silverado LTZ Z71, 16 Camaro SS Join Date: Nov 2009
I really want to see how your custom cam works with your heads. Don't do the blower yet.
What type of valve springs are you going with ? Who is making your cam? What peak rpm are you looking at? Back in my LS days 110-112 LSA was always the popular choice. Wonder why everyone is doing higher now... |
09-14-2017, 01:44 PM | #27 | |
I will try to find out this weekend if the lobe sep is a mechanical issue or a tune issue.
09-14-2017, 02:16 PM | #28 |
I am definitely interested to see Prays results with the Cam.
2016 NFG 1SS A8
