12-27-2021, 08:27 PM | #15 | |
Drives: HBM ZLE Join Date: Aug 2017
King knows his stuff so if fuel looks good then send it. Would give me an idea how much e can be added with just injector and pump |
12-27-2021, 08:32 PM | #16 | |
All really depends. No Cam and Max effort bolt ons, usually the high side will drop first. With a cam and max effort then the low side is a problem. It really all depends on how much power and mods. I think IMO people should skip the JMS booster and put a real pump in. It just makes more sense to me. I know some people dont want to drill the tank, but if done right its not an issue, and you'll never need to worry about needing fuel upgrades in the future. I'm at 850whp and my low side is holding at 80+ PSI even at E40. I don't see the high side holding pressure with the ported blower and pulley on E60 but every car is different. They didnt expect my car to be able to run E40 but it did, but i like to keep it at E30 as it starts to get into the 6.3ms range at E40.
928rwhp - 93 | 1040rwhp/898rwrq - E65 SAE
LME 377 LT4 Short Block | Magnuson 2650 80mm upper w/13% lower (9.06) | DSX Lid & Valve Covers | CSP Custom Cam w/32% fuel lobe | CID Heads | NW 103mm TB | Roto Fab Big Gulp | CSP 2" Headers w/Green GESI Gen 2 Cats | Borla 3" Full Cat Back w/ S-Type| Mighty Mouse Wild Catch Can| Custom Holley Low side Fuel system| TooHigh PSI Port Injection w/Holley Controller | Forced Inductions Interchiller w/2 gallon fender tank | TK Performance built 10L90 |
12-27-2021, 08:53 PM | #17 |
Drives: 2023 ZL1 M6 Join Date: Sep 2018
I think it will run out of high side on that setup with e60. Many guys are ok letting high side slip a few hundred psi, but once it start falling 3-400 it gets in trouble quick. The upgraded high side does very little on a lt4 car. Run it on pump and ease the ethanol in and watch the high side fuel pressure close. Low side and injector is solid. I would trim the E content back until you do a camshaft.
2024 Riverside Blue ZL1 M6
Magnuson 2650R, NW 103, Roto Fab Big Gulp, Jet Hot Coated ARH 2 inch LT's, Stainless Works NPP, Too High PSI Billet Valve Covers, Mighty Mouse Wild CC Signature Forged 20x10.5/20x11.5, 295/30-315/30, BMR springs, BMR Cradle lockout, AAD Billet Control/Trailing arms 2023 Vivid Orange ZL1 M6 - sold 2019 Riverside Blue ZL1 A10 - sold |
12-27-2021, 09:06 PM | #18 | |
Drives: 2019 Chevy Camaro ZL1 M6 Join Date: Jul 2019
Kong Stage X Port, NW103, LPE HPFP, XDI +30 Injectors, ARH Headers, Flex Fuel, JMS Booster, AWE Touring, Elite E2-X CC. Stock heads, stock cam, stock pulleys: Tuned by KingLT1. 740whp Uncorrected on e50
12-27-2021, 09:30 PM | #19 | |
Drives: 19’ ZL1 A10 / 16’ C7Z M7 Join Date: Apr 2021
-CAI -LPE TB -Headers/Exhaust -Flex Fuel -E50-E55 .84 Lambda With E50 the low side was just starting to drop with no JMS. Injectors were 5.5 I believe. That was also after he added two degrees of timing “24” then had to add fuel back in from picking up power. The FPCM settings haven’t been played with yet. I just got my TCM unlocked and installed. Waiting for the HPFP and injectors to show up so I can finish the install. On E35 it had plenty of fuel. |
12-27-2021, 10:37 PM | #20 |
Brett @ Pray Performance has run the FIC +30 & LPE HPFP @ 700whp on his Dyno with full pump E and there was plenty of fuel on a stock cam ZL1 with similar mod list as OP.
Either way won't really know until I log it. My guess is it will handle E60 with stock low side. I will probably have to dial back high side pressure to take strain off low side and that will make the injectors work harder but there will be plenty of injector to work with.
2016 NFG 1SS A8
12-27-2021, 11:18 PM | #21 | |
12-28-2021, 07:52 AM | #22 | |
What about a cam, or am I missing it? You will under perform without one.
'20 ZL1 1LE A10,
12-28-2021, 08:15 AM | #23 |
Installing a cam is whole lot more work. It’s pretty much a full on build. Everything the OP is doing is essentially bolt ons.
12-28-2021, 08:34 AM | #24 |
Installing a cam was originally the go to method on these cars to get more fuel and gain another 50-70whp. This ideology was used before there was more affordable fueling options. It's also a great way to make more power without spinning the stock supercharger harder. However things have evolved over the years and again we now have cheaper fueling options along with larger superchargers and improved port programs for the stock supercharger to increase efficiency.
For example...look up airtroops thread on his basically stock motor LT4 CTS-V3. With a 2650 swap and ToohighPsi port injection plates the car made over 800whp on E85. That is with stock heads, cam, exhaust down to the cats. You can get LPE DI pump and +30 injectors for around 3,740.00. Or you can get Mikes Port Injection plate system for around 2k. Both of those options are cheaper then paying somebody to pull the engine to swap a cam. The LPE +30 combo is going to max around 700whp on full E, probably 750ish with E50 with a bolt-on LT4.... Mike's PI plate system will go 800whp + before needing to address some other areas of the build but the fueling is there for 1k whp. Changing injectors and high side is much more simplistic but obviously more limited. Swapping a cam is going to run 5-6k(unless doing the work yourself) and you will make about 700-730whp on 93. Maybe 750whp with E30 mixed in. So a little more power then the LPE +30 bolt-on combo but nothing drastic. I bet the LPE +30 combo on E50+ runs more consistent being it will be able to tolerate much higher MAT without pulling timing. Either way the OP already has a 11:1 H/C 2650 C7Z making too much power for the street. He wants this build to be similar to my car. Make just enough power to still be useable on the street from a second gear launch. This should do the trick...It should be a low 10's mid upper 13x combo on 20" wheels. Full drag pack at the track with passenger seat pulled it should have enough to break into the 9's....plenty for a street car.
2016 NFG 1SS A8
Options-2SS Leather/NPP Perf. mods-Whipple 2.9/Fuel System/Flex Fuel/103mm TB/Rotofab Big Gulp/Cat Deletes/Corsa NPP Per. times- 10.5 @ 137 w/ 1.8 60ft Full weight on 20's 1200DA Last edited by KingLT1; 12-28-2021 at 08:57 AM. |
12-28-2021, 09:06 AM | #25 | |
-As long as I can run E50 and up I will be happy. Should still be able to stay fairly aggressive on timing and keep the exhaust fumes to a tolerable/enjoyable smell. Factory GenV cams seem to burn very clean on E40+. Last edited by CamOnlyJabroni; 12-28-2021 at 09:20 AM. |
12-29-2021, 04:37 AM | #26 |
Should be interesting to see how it turns out although without port injection or meth, I still the think the high side is going to be limited to around 700whp.
12-29-2021, 08:06 AM | #27 |
Also I'm sure their are a few of us that wouldn't mind some tips on the injector and pump install
I would think with the extra airflow from the port and pulley, it might offset the extra fuel from the upgraded high side and you'll be around e50 still. Looking forward to the results, might be choosing different mods, because I was looking at cam/heads next |
12-31-2021, 06:18 PM | #28 |
Saw your ad, decide to screw it and go bigger blower? Or just paying a core charge
