10-08-2021, 03:00 PM | #29 | |
We have made 870RWHP using XDI 30% injectors with a LT4 high side pump. At that point the high side pump is tapped. I wouldn't recommend trying to run any mix of E at those power levels. There just isn't enough injector/pump to support it with OEM LT4 components. The LPE pump is only about 10% better than the LT4 pump. If you're trying to run full E85 on DI only the XDI XFP system is currently the only option. |
10-08-2021, 06:06 PM | #30 | |
2016 NFG 1SS A8
10-09-2021, 06:08 AM | #31 | |
Drives: 19' ZL1 A10, w/pdr Join Date: Sep 2014
Another question, I will also be adding a low side pump but, don't like the idea of tapping into the fuel tank, is there an alternative?
BTR Stg II cam w/ 38% fuel lobe, ARH 2" headers into 3" w/cats, AWE Touring, Kong X port, Weapon X triple ht exchangers, NW 103, Rotofab big gulp, DSX lowside, TCM tune, BMR Lockout, Mustang dyno 720 rwhp, 634 rwtq on 93 pump.
10-09-2021, 09:22 AM | #32 | |
Lingenfelter makes a drop in pump assembly that would give you more low side headroom. I do think it would work fine for many builds especially with a JMS hitting it with a few more volts when in boost. The Fore triple pump setup is the ultimate solution and is what LPE uses majority of the time on the 1000hp builds.
2016 NFG 1SS A8
10-09-2021, 12:16 PM | #33 |
Drives: 2020 Rally Green ZL1-1LE Join Date: May 2020
Has anyone used a DeatchWerks 440 pump on the low side? Any real benefit above the factory pump?
10-09-2021, 03:11 PM | #34 |
Not sure...have heard some using a Hellcat pump as a upgrade.
2016 NFG 1SS A8
10-09-2021, 03:41 PM | #35 |
Former GM Technician
Drives: 2018 ZL1 A10, 06 Silverado Duramax Join Date: Sep 2009
Deatschwerks told me this week, that they are currently developing a dual in tank bucket kit for our cars.
2018 Camaro ZL1 A10
Rotofab Big Gulp, Nick Williams 103, Magnuson 2650, 9.17" (14%) lower, 90mm upper, Vengeance Racing Heads (LME) Cam Package (Cammotion Stage 1), Johnson Lifters, JMS Voltage Booster, Lingenfelter high flow check valve, BBK shorty headers, Custom 2.75" down pipes, Gesi Gen2 high flow cats, MM catch can 791whp, 772ft-lbs SAE Just added 30% XDI Injectors, LPE big bore hpfp, Flex fuel. Elite tuning, results coming soon. 2006 Silverado Duramax Diesel MPI Compound Turbo 40% over Injectors Efi Live DSP5 Tuning Follow me on Instagram: Swisstyphoon1980 |
10-09-2021, 03:54 PM | #36 | |
I've referred to your corrected 830 wheel number here before as being close to what KaTech sees as the limit for the OEM high side on pump gas at lower elevations including your shop.
If I make 830 corrected wheel up here using a 20% correction it's like 700 measured HP up here, which means I can run some E85 to help make up part of the loss and ask more of my OEM pump/injectors. I don't yet know how much. In this cool part of the year at your KaTech shop, how much of a CF on average would your dyno use, 3-5%? Quote:
'20 ZL1 1LE A10,
OEM short block, LME heads/valve train, E2650. 100+ octanes, no eth, no meth, no N2O. 2/23 - 1031/1004 wheel. 4/23 - 1.41/9.61/145 at DA 7000 ft. (only made five passes). 2/24 - LME 390, E2650, FBO, 100 oct.; 1116hp/ 1063tq; 109 oct. dyno next. Last edited by JSH; 10-09-2021 at 07:44 PM. |
10-09-2021, 06:12 PM | #37 |
I tried a DW400 with a JMS voltage booster. I don't think it was worth the effort over a typical LT4 in-tank. I want to say around 800 WHP on 93 octane I was out of fuel on the low side yet again. I should have went right to the Fore setup when the LT4 wasn't cutting it... Oh well, my shop is getting really good at dropping my fuel tank these days.
10-09-2021, 06:57 PM | #38 | |
FYI, I picked up an extra in tank pump for $140 out the door so I'd have something on hand to mod when the time came. |
10-16-2021, 11:31 AM | #39 | |
LPE's Big Bore high side ($1735) https://www.lingenfelter.com/product...l#.YWm7cRrMJMs XDI 30% injectors ($2500) https://shop.katechengines.com/produ...-injectors-30/ DI (LPE $6400) seems to be the next step up. Really no choice on the high side but numerous choices on injectors. KingLT1 has recommended FIC +30's. Basically all I've done is confirm what others have said here previously.
'20 ZL1 1LE A10,
OEM short block, LME heads/valve train, E2650. 100+ octanes, no eth, no meth, no N2O. 2/23 - 1031/1004 wheel. 4/23 - 1.41/9.61/145 at DA 7000 ft. (only made five passes). 2/24 - LME 390, E2650, FBO, 100 oct.; 1116hp/ 1063tq; 109 oct. dyno next. Last edited by JSH; 10-21-2021 at 07:45 AM. |
10-21-2021, 07:01 AM | #40 |
Drives: Turbo 6.2 Join Date: Feb 2019
Is the general rule for upgrading injectors once you hit the 6ms threshold?
2016 Turbo Camaro SS - 800hp/900tq 9.7@146
2018 LTZ Z71 Redline Silverado - 381hp/420tq 13.8@100 |
10-21-2021, 08:56 AM | #41 |
Depends on your SOI table. If it's adjusted to start injecting fuel as early as possible then you can get away with higher pulse widths. I believe the caveat is that it costs a little combustion efficiency but allows us to get more fuel in the chamber without spraying it out the exhaust causing a false rich condition. In a perfect world we don't do much with SOI and have enough fuel to keep injectors down around 5ms or less.
2016 NFG 1SS A8
