07-14-2021, 07:56 PM | #29 | |
735 rwhp | 665 rwtq Magnuson TVS 2300 80mm pulley | Kooks 1 7/8" LT headers | JRE smooth idle terminator cam | LT4 FS & injectors | TSP forged pistons & rods JMS PowerMAX | DSX flex fuel kit | Roto-Fab CAI | Soler 95mm LT5 TB | 1LE wheels | 1LE brakes | BMR rear cradle lockout | JRE custom tune 1100 - 1/30/18 | 2000 - 1/31/18 3000 - 2/06/18 TPW 2/26/18 3400 - 2/19/18 | 3800 - 2/26/18 4300 - 2/27/18 | 4B00 - 3/01/18 4200 - 3/05/18 | 4800 - 3/14/18 5000 - 3/16/18 | 6000 - 3/19/18 Last edited by arpad_m; 07-14-2021 at 09:54 PM. |
07-15-2021, 07:10 AM | #30 |
Limitless Imagination
Drives: 2018 ZL1 & 2022 Hayabusa Join Date: Dec 2016
When I got my car a few weeks ago, it only had 2 screws for the temp plate so when I mounted mine I drilled out the other 2 dimples. I actually ran a tap through the holes since had it handy, but really not needed for this.
For mounting screws, whatever you get just make sure they're stainless. I used black stainless in my case.
2018 Camaro ZL1 - Black
- OEM Options: A10, Exposed Carbon, PVR, Nav, No Sunroof - Lightly Tinted GM Dark Tails, DD Side Markers, Morimoto 5000k, 100% LED - RotoFab Dry, Forgestar CF5V (ZLE Spec), Eibach Pro, AeroForce Interceptor, GT4 Tow Hook - Carbon Fiber (Satin): Radio, Shifter, Steering Wheel Controls, Shifter Top, AC Vents, Side Mirrors & Shark Fin 2022 Suzuki Hayabusa - Brilliant White Pearl & Shocker Yellow Wheels - +4 Arm, 240 OEM Wheel, Brock's CT (Ti) Exhaust, 1.25" drop, etc... |
07-15-2021, 09:32 AM | #31 |
Drives: 2018 Camaro ZL1 Join Date: Aug 2018
I've just had the 2 screws the dealer put in for nearly 3 years and the license plate is angled out away from the bumper. Haven't had any issues with it scratching the bumper.
07-15-2021, 11:16 AM | #32 |
Drives: 2018 Camaro ZL1 1LE Join Date: Mar 2021
Awesome, thanks everyone!
07-19-2021, 02:09 PM | #33 |
Update!!
Finished polishing the car finally. Saved the back bumper for last as it was the only area on the car that had issues, and it had two areas that needed help, besides the frame area. I think the before on these in real life was way worse than they look in the pictures. I am really happy with how this and the whole car turned out though!! Going to be coating the car and then the new plate is going to go on with the silicone frame. |
07-19-2021, 03:11 PM | #34 |
Drives: 2021 Camaro ZL1 Join Date: Jan 2016
Looks good.
I'm adding this late but I also got a black silicone frame from Amazon, marked the locations and drilled 4 small pilot holes, then used the supplied self-tapping screws. https://www.amazon.com/dp/B08MF38N9Q...ing=UTF8&psc=1 Different brand than the other link, but looks similar other than the included screw caps. Worked perfectly. I had a nice (read expensive!) carbon fiber plate frame from my '16 SS I was planning to use, but on the '21 there's apparently less clearance between the body and the backup camera housing and I couldn't get the thicker carbon frame behind it and up high enough to work correctly. Sent from my SM-A125U using Tapatalk
ZL1 Coupe, Wild Cherry Tintcoat, Black Metallic Center Stripe, A10, Red Knee Pads, Red Seatbelts, Nav. Ordered 12/12/2020, Built 1/14/2021, Arrived at Dealership 2/23/2021, Took Delivery 2/27/2021.
07-19-2021, 04:03 PM | #35 | |
This was the route I was leaning toward as far as drilling small pilot holes first. Glad this worked out well and thanks for posting! Yea my silicone frame looks like the one you have there, but its not a side slide type. I think I still prefer no frame, but the added protection against scratching I think is worth it, plus the small black border style frame is pretty unobtrusive and the black kinda matches the black trim. |
07-19-2021, 05:32 PM | #36 |
You're welcome. That was my same reasoning, and it works perfectly and looks simple and clean.
07-19-2021, 06:13 PM | #37 |
lol never even looked at it or cared that much
