BeckyD @ James Martin Chevy
Old 11-13-2023, 05:20 AM   #1
Vladislav
Drives: Camaro 6 1LT V6 2019
Brake rotors choice
Hi guys!
I want to buy new front brake rotors for my Camaro. I have 1 piston brake system – JL9 and it’s my daily drive car (I don’t have track days, 95% of the time it’s normal driving). On RockAuto I found rotors from companies: Dynamic Friction, Power Stop, R1 Concepts and ACDelco. Please, could you recommend a good producer? I think the best way is to take the original – ACDelco but what can you tell about quality from other producers? What would you buy?
Thank you in advance!
Vladislav is offline   Reply With Quote
Old 11-13-2023, 06:45 AM   #2
Christian1LE
Drives: 2004 BMW 330CI, 2022 1SS 1LE
I would stick with stock. I run a 1LE and I basically only do trackdays. The first year I ran stock and they held up just fine for a full year until eventually running low on thickness. I switched to Girodisc on the second year and they have been fine as well. The girodisc is a lot tougher as far as not losing thickness but it's getting "heat cracks" to the point where I'll also need to change them after 1 year. I think for just driving on the road you just need something reliable and inexpensive. There is no need to get anything performance focused because your brakes will never be pushing near 100% use.
You can also keep an eye on the member classifieds and maybe pick up an extra set from someone who is selling them.
Christian1LE is offline   Reply With Quote
Old 11-13-2023, 08:39 AM   #3
Vladislav
You are right regarding stock, I just found a sets of rotors and pads for the good price, that’s why I asked about other producer’s quality
Old 11-13-2023, 10:10 AM   #4
dmcmahan60
dmcmahan60's Avatar
Drives: 2017 SS
If you are not tracking your car, just get a set of ceramic pads and solid rotors from Stop Tech and call it a day.
dmcmahan60 is offline   Reply With Quote
Old 11-13-2023, 11:16 AM   #5
Gunkk
Thank you Al Oppenheiser!
Gunkk's Avatar
Drives: Red Hot A10 ZL1 Convertible
Power Stop is fine. I have their Z26 pads on my car and they work just fine for street use, and with zero dust!
Gunkk is offline   Reply With Quote
Old 11-13-2023, 03:18 PM   #6
Vladislav
This producer has a good price for the rotors, I am thinking to buy it. Thanks!
Old 11-13-2023, 03:20 PM   #7
Vladislav
I didn’t find it on Rockauto but thanks for your answer!
I can buy only in this online store because I live not in US
Old 11-13-2023, 09:35 PM   #8
bertie
Drives: 2001 Camaro
My friend is getting Power Stop rotor for his new Camaro project. He also got them on his truck along with new gear wheels and nittos. Been doing great for a year as DD.
bertie is offline   Reply With Quote
Old 11-15-2023, 02:15 AM   #9
Vladislav
Good then I buy it also, should be ok for daily use. Also, a good price for the set on rockauto
Old 11-15-2023, 09:57 AM   #10
ctrlz
What level of Power Stop rotors are we recommending?
I see:
1) Drilled/slotted
2) Coated
3) Stock/OEM equivalent
Old 11-15-2023, 06:41 PM   #11
arpad_m
arpad_m's Avatar
Drives: 2018 Camaro 2SS A8
I never understood the allure of slotted or drilled rotors (on our streetable cars) with their smaller surface area, holes to clog up with brake dust and sharp or weakened edges prone to start cracking... is it esthetics maybe?
735 rwhp | 665 rwtq
3000 - 2/06/18 TPW 2/26/18
Old 11-16-2023, 09:09 AM   #12
ctrlz
That's what I suspect is the main allure.
Some brands also offer regular and high-carbon steel options. From what I've read the high carbon is not worth it. Now the coating process does seem to offer some corrosion resistance.
Of the 3 options I listed, I would favor the coated, although I still have stock rotors on my 2SS.
Old 11-16-2023, 01:10 PM   #13
Vladislav
For the every day use I think to buy coated rotors + ceramic pads. May be if you drive on a track better to have more performance solutions.
