Old 03-27-2022, 12:39 PM   #1
Heads-up
Drives: 2010 2SS
Lower control arm removal
I'm installing LCA from BMR. The right side arm will not come off. The left side came off easily. The bolt goes through the frame and then the lca has a rubber bushing with a steel core. I've tried heat and impact and the bolt wont slide out of the sleeve to let the lower control arm drop free. It barely rotates under all the force i can put on it with a 1/2 inch 20" bar. It may be bent and thats' why it wont slide out of the control arm. I may have to cut the head off the bolt. Before i take drastic measures has anyone had this issue or a suggestion?
Heads-up is offline   Reply With Quote
Old 03-27-2022, 12:47 PM   #2
Heads-up
Drives: 2010 2SS
Second picture is of the removed left LCA
Old 03-27-2022, 12:54 PM   #3
demonspeed
not afraid of the wall
demonspeed's Avatar
Drives: Camaros
Have you tried the big ficking hammer?
2023 1LE 1SS BCD GCF JF5 MN6 SIA SLN UQT
10/13/22: 1100
Past Camaros: 13 1LE|02 SS|01 Z28|00 SS|91 1LE|91 Z28|89 IROC-Z
demonspeed is offline   Reply With Quote
Old 03-27-2022, 02:34 PM   #4
Heads-up
Drives: 2010 2SS
Yes I have tried a hammer. I cant hit it straight on the end due to the exhaust being partially in the way. I put a punch on the bolt it and hit it as hard as i can. I'd pull the exhaust, but the last owner cut off the exhaust pipes and welded new mufflers on. I have to cut them off and get them re-welded.
Old 03-27-2022, 04:34 PM   #5
fz4k98
Drives: 2013 1ss
If there is room, setup a c clamp by putting an oversized socket over the bolt head so there is no pressure on the bolt head. the other end of the c clamp pressing on the oher end of the bolt. Apply as much c clamp force as possible, then take a hammer and screwdriver or something to hit the side of the bolt. If it moves, retighten the c clamp and repeat until it is loose enough. Make sure to use some type of liquid wrench or something on it also.
I have had luck doing this as there is pressure on the bolt to extract it and the suden hit with a hammer provides a shock that may loosen it some.
Good luck/
fz4k98 is offline   Reply With Quote
Old 03-27-2022, 05:42 PM   #6
demonspeed
demonspeed's Avatar
Drives: Camaros
At this point, with everything you’ve attempted, just cut it out and get a new one. It’s likely rusted to crap anyway.
10/13/22: 1100
Old 03-27-2022, 07:02 PM   #7
Heads-up
Drives: 2010 2SS
I'll try the c clamp. Thanks for that suggestion. If that doesn't work I'll cut it.
Old 04-08-2022, 09:49 AM   #8
SS 310H55A
Drives: 2014 Camaro SS
Try a hammer and a punch
2014 SS | MGW Flat Stick shifter | Raceseng Slammer shift knob | Z/28 spoiler and grill
SS 310H55A is offline   Reply With Quote
Old 04-08-2022, 12:05 PM   #9
gsxrturbo
Drives: 2010 ss
soak it with pb blaster and let it soak a day or 2
gsxrturbo is offline   Reply With Quote
