BeckyD @ James Martin Chevy
Old 05-30-2020, 01:56 PM   #1
MrRuss
MrRuss's Avatar
Drives: 2016 Camaro 2SS
Front suspension "bump/clunk"
Hey forum,
A few weeks ago I started noticing a "bump/clunk" in the front suspension when I go over small bumps in the road. My car is a '16 2SS with 41K on it. If the bump is one side or the other it doesn't do it, only if the bump is even across the road and both tires hit it simultaneously and not every time. I have mag ride and it doesn't seem to matter what mode I'm in and the modes are working correctly.
Haven't gotten under it to look myself (it's not even June and its > 100 degrees everyday here now) I have an appointment with the dealer to look at it Monday but I'd like to have some ideas first. Gonna try to at least get it on the ramps in my garage to give it a look tomorrow. Any known trouble spots I should check??
Thx,
Mr Russ
Tim "the tool man" Taylor is my hero
My Garage:
'16 Chevrolet Camaro 2SS, Summit White, Adrenaline Red
-- Rotofab CAI, Soler TB, 1 7/8 coated LT's, Full 3" mids, 3" Stainless Works NPP mufflers, Flex Fuel, E85/91 tuned
'20 Honda Oddysey Elite 25th Anniversary Edition
--wifes car, she said "No more SUV's" after the 2 CX-9's totaled
MrRuss is offline   Reply With Quote
Old 05-31-2020, 06:20 AM   #2
snowwhiteZL1
Drives: 2018 ZL1 White
Mr Russ
Please check the front wheels lug nuts torque, if they’re up to specs, the check the sway bar, the bushings might have some play in it. Hope it helps.
snowwhiteZL1 is offline   Reply With Quote
Old 05-31-2020, 12:48 PM   #3
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '21 ZLE A10
Sway bar end link most likely. Grab an 18mm wrench and a 6mm hex. They clunk if they are 1/16 of a turn loose.
'17 ZL1 A10 Mosaic Black PDR/Nav 2:03.08 VIR Full 11.003@129.2 1.75 (sold)
'15 Z/28 #325 Black a/c & stereo. 2:10.1 VIR Full (sold)
'12 ZL1 A6 Black 10.52@131 1.55 60' 2:13 VIR Full (sold)
Stephen12ZL1 is offline   Reply With Quote
Old 06-10-2020, 08:45 AM   #4
MrRuss
MrRuss's Avatar
Canceled the dealer appointment. Got the car up in the garage and tightened up a few things. The sway bar end links were slightly loose. Main thing I found was driver side front lower control arm bolt at the knuckle was not tight at all. Took it out for a spin no noise.
Mr Russ
My Garage:
Old 06-10-2020, 11:32 AM   #5
Xaxas
Xaxas's Avatar
Drives: 2019 2SS 1LE
This happened to me, apparently, there's a TBS for that and there's some sort of new screw that will prevent it from happening in the future.
Current: 2019 2SS 1LE aka "Blanc"
Previous: 2017 2LT aka "Noire"
Mods: Chevrolet Performance Suspension || K&N Cold Air Intake || Borla ATAK Mufflers + Catback system || MRR 650 ZL1 replicas with squared 285/30 Michelin Pilot Sport 4S || ZZP 4 piston brake kit + braided brake lines || BMR everything (Solid/Lockout cradle bushing are a MUST in Camaros)
Xaxas is offline   Reply With Quote
Old 06-10-2020, 04:30 PM   #6
Bumbleboy92
Long hauler
Bumbleboy92's Avatar
Drives: 2022 Camaro 2SS 1LE
Did it sound like this?
Bumbleboy92 is offline   Reply With Quote
Old 06-11-2020, 12:28 PM   #7
MrRuss
MrRuss's Avatar
Originally Posted by Bumbleboy92 View Post
Nope, and I spoke too soon. Still doing it
Mr Russ
My Garage:
Old 06-21-2020, 12:15 PM   #8
MrRuss
MrRuss's Avatar
Got it narrowed down to the driver side and only on raised bumps, not dips. Raised it up again and spent more time looking and moving joints with a pry bar, still not finding any thing loose.
Mr Russ
My Garage:
Old 06-22-2020, 01:51 AM   #9
Bumbleboy92
Long hauler
Even though the sounds not the same as my noise, check the torque on all the suspension pieces.
My noise is coming from the lower control arm but coming loose, had an alignment done and they told me it was no where near spec
2022 2SS 1LE - Cold Air Inductions Elite Carbon CAI
2016 1LT v6
- Totaled
Happiness: Infinite
Old 06-22-2020, 10:37 AM   #10
MrRuss
MrRuss's Avatar
I did have a car that once made noise like yours when turning the wheels back and forth, it was a bad steering rack. Anyway, I checked every bolt and found nothing loose. It's at the dealer to be checked. Thx.
Mr Russ
My Garage:
Old 06-23-2020, 10:45 AM   #11
MrRuss
MrRuss's Avatar
Well they replaced the sway bar end link nuts/bolts yesterday and that did not fix it, I could have told them that .
They still have it, guess we'll see what they come up with today.
Mr Russ
My Garage:
Old 06-24-2020, 06:35 PM   #12
MrRuss
MrRuss's Avatar
It was the driver side strut, replaced it. Now I need to replace the passenger side. Not going to have the dealer do it, way to much $$. I wanted them to diagnose and take ownership of the repair and they did. One troubleshooting indication, the driver side would not give much when simply pushing down on the bumper, the passenger side did.
What is a reasonable life expectancy for the MRC struts? My car is 4 years old and ~ 42K miles, good roads here and I don't abuse it. Should I consider replacing the rear ones?
Mr Russ
My Garage:
Old 07-15-2020, 11:59 PM   #13
BigGuy81
Drives: Man
Send a message via ICQ to BigGuy81 Send a message via AIM to BigGuy81 Send a message via Yahoo to BigGuy81
I don't think life expectancy is any different than normal shocks. Sometimes parts go bad for a myriad of different reasons.
BigGuy81 is offline   Reply With Quote
Old 07-17-2020, 08:36 PM   #14
WTFO
Drives: 2018 Camaro 1SS
My 2018 SS with 26K on it is knocking when I go over shallow ripples in the road - from research seems it is a systemic problem with the cars and the front end knock - so far have not found any resolution - running BMR fully adjustable anti roll bar setup front and rear and have checked all bolts on everything and checked for clearance on the roll bars nothing hitting
WTFO is offline   Reply With Quote
