06-19-2023, 05:17 PM | #1 |
Drives: ZL1, S2000 Join Date: Mar 2023
Driver's seat memory-doesn't always work
Hello folks,
Has anyone experienced the seat not either moving upon exit or moving forward upon entry randomly? Both options are set up in the infotainment vehicle settings but this thing goes haywire sometimes by not moving the seat accordingly. What I've done in the past is go into the settings and disable and enable it back on again and it works again consistently for like a week or so. Any clues here? Last edited by 2023ZL1RapidBlue; 06-19-2023 at 05:58 PM. |
06-19-2023, 05:31 PM | #2 |
Drives: 2017 Bright Yellow ZL1 6spd Join Date: May 2010
Same with mine from day one. I just learned to live with it.
2017 ZL1 Bright Yellow w/ black center stripe, 6 speed, CF gas door, PDR, Navi
06-19-2023, 06:00 PM | #3 |
06-19-2023, 08:57 PM | #4 |
Looks like I'm lucky, mine has worked 100% of the time for 5 years. One would think eight model years should be enough to iron out all these kinks, but hey,this is GM
If it makes you guys feel better, my wife has a Traverse with a known flaw that GM didn't fix from 2009 (first MY) to 2017 (last MY before refresh), I'll have to take it in, the gauge cluster needs to come out and get replaced... unless she can live with it (hint, hint )
06-19-2023, 10:19 PM | #5 |
D3RPZILLA
No issues as of yet but I've pretty much set my seat position and have never adjusted it since and I don't use the auto exit stuff as I figure this will wear out the motors fairly quick with how things go with cars these days, lol.
2021 Camaro ZL1 Satin Steel w/a10/PDR/CF/Red Belts/Navigation
Website: z1lla.com | YouTube: youtube.d3rpzilla.com YouTube Playlists: Performance Mods | Interior & Exterior Mods | Other Mods |
06-20-2023, 06:43 AM | #6 |
Drives: 1977 Pontiac Trans Am Join Date: Oct 2019
Seat not moving
So it is not a glitch it is a design. I noticed this as well and it has to do with setting the parking break before you turn the car off (I am assuming you have a manual). If you set the brake and then turn the car off the seat will go to the exit position and then when you get back in it will return to the driving position once the car is started. If you set the brake after you turn the car off the seat wont move.
06-20-2023, 08:18 AM | #7 |
Drives: 2017 ZL1 Join Date: Mar 2022
My seat moves forward when I open the door... I'm 6'3 so I have to get my hand down fast enough to stop it from smashing my legs. Not sure how I stop it from doing this.
06-20-2023, 08:33 AM | #8 |
My 2017 ZL1 is the same way which is not an issue with me.
06-20-2023, 09:34 AM | #9 |
I think If I start the car in neutral, the seat does not move into the memory location, But, if I start the car in `1st gear, it will move most of the way into the memory location. It's weird.
06-20-2023, 09:43 AM | #10 |
If vehicle is in running it does not work. Car has to be off then it will activate when you open the door. I have tested this a few times.
2023 Camaro ZL1 Vert TR-6060 Sharkskin "Sharky"
Firecracker Red Wrangler Willys, 3.6L eTorque, 850RE 8 speed automatic, 25W Willys package, Technology Group, Convenience Group (aka $600 garage door opener), Cold weather Group, Trailer Tow and HD electric group with AUX switches, 3 piece black freedom top. |
06-20-2023, 09:44 AM | #11 |
Drives: 2017 ZL1 6spd Convertible NFG Join Date: Jan 2017
The parking brake has to be set for it to move forward when I get in. Took a while to figure that out. It always moves back for exit. This is a 2017 M6.
06-20-2023, 03:34 PM | #12 |
Set your seat where you want it to go when you turn off the car. Hold the SET button until it beeps, then IMMEDIATEDLY press the Seat Exit button. Then it should start moving to that seat seating when you turn off the car, instead of cramming you forward into the dash.
2020 Camaro 2SS - Riverside Blue, NPP, Magnetic Ride, Sunroof
RUXIFEY Smoked LED Side Marker Lights / Black SS emblem on rear bumper / Blue SS vinyl overlay on front bumper emblem / Wildhammer Rear Dark Reflectors / Trim Illusion Gloss Black Door Handle Covers / eBay Black Fuel Door / Screaming Chicken Fender Hash Marks / Color-Matched G2 Caliper Paint RE Audio RFX10D4 10" Sub / Hand-made sub enclosure / Hifonics Zeus ZRX1200.1D amp / JL Audio LoC-22 line output converter / Sub Thump Plug N Play T-Harness With ANC Defeat Harness Kit My Camaro Journal |
06-20-2023, 04:14 PM | #13 | |
fo'shizZL1
Drives: 2017 ZL1 Join Date: Aug 2017
thanks for the intel!
2017 ZL1 M6 Black | Maggie 2650 // 103TB // Big Gulp
Past Rides- 2014 ZL1 M6 Red Hot | Tons of mods 2004 CTS-V M6 Silver | Many mods 1995 Corvette M6 Torch Red | A few more mods 1992 Camaro M5 White | A few mods |
06-20-2023, 04:18 PM | #14 | |
