04-08-2019, 09:57 AM | #1 |
Drives: 2019 zl1 6 speed Join Date: Jul 2017
Where does the wideband go
Hey guys, just curious, how do you hook up your wideband sensor to etune? Do you just unhook a o2 sensor and replace it with the wideband, or do you need an extra bung to thread it into? I'm looking at headers and don't know if I need to find a set with 3 bungs, or just two for the o2 sensors. I've looked everywhere and haven't been able to find answer.
04-08-2019, 10:20 AM | #2 |
Drives: 2016 Camaro SS Join Date: Sep 2018
You will need to have an extra bung welded in for the wideband.
04-08-2019, 01:14 PM | #3 |
Dang, I was afraid of that, thanks for the response.
04-08-2019, 06:55 PM | #4 | |
Drives: 2016 2SS A8 Convertible Join Date: Aug 2010
04-18-2019, 12:58 AM | #5 |
Drives: 2017 2SS M6 Join Date: Jun 2013
I asked on HP tuners forum. and directions for o2 gauge said it will be reading lean if after the cats. your probably running rich.
04-18-2019, 07:27 AM | #6 |
Thats if you still have cats
Adrenaline Red
20" 5 Spoke Black Black Side Spear Dual Mode Exhaust MRC Splash Guards 1G1FG1R74G0124089 |
04-18-2019, 08:31 AM | #7 |
Drives: 2012 2SS CAMARO 45th Join Date: Apr 2011
Just have your rear o2's turned off and remove them. You can use that bung for your wide band. Or anyone who knows how to weld can toss one in for pretty cheap, you can find the bungs on ebay for a few bucks
04-18-2019, 11:37 AM | #8 |
it will read lean if put after the cats.
07-24-2020, 08:03 AM | #9 |
Drives: firebird Join Date: Jan 2010
My understanding is for tuning you want your trims off anyways so can disconnect a sensor and add your wideband in. Then after tuning then trims back on. Sound right?
07-24-2020, 08:31 AM | #10 |
Much better off with an AEM wideband installed full time. That way you can log it with HP Tuners and see it on the street (on the gauge) too. Just weld in an extra bung into your header collector...done.
