01-25-2017, 08:00 PM | #1 |
Drives: 2013 Camaro SS LS3 Join Date: Jun 2015
Anyone have a Throwout Bearing fail?.... Well mine did (PICS)
My car is squealing like crazy! I'm pretty sure it's the throwout bearing at least that's what it sounds like. It only has 32,xxx miles on it. I also have a spec stage 3+ clutch. Is this normal on these cars? And also does anyone sell just the throwout bearing by itself?
Romans 5:8 But God demonstrates his own love for us in this: While we were still sinners, Christ died for us. -Fastlane Cold Air Intake, NPP cat back exhaust, Stainless Works LT Headers, 2r max camshaft, Stage 3 Ported Heads (Manley Stainless steel values, titanium retainers, dual valve springs, bronze guides), Wiseco Forged Pistons, K1 Forged Rods, Clevite Bearings, Factory Crankshaft, Comp Cams rocker arm trunion kit, Morel 5315 lifters, JP performance single billet timing chain, Melling oil pump, Spec stage 3+ clutch and flywheel, BMR trailing arms, Nitto 555r 305/35/20. Last edited by booneSS13; 02-11-2017 at 08:12 PM. |
01-30-2017, 07:23 AM | #2 |
MM.CC
Drives: 2010 Camaro 2SS LS3 Join Date: Jan 2011
skf bearings make them for the slave cylinder. its skf #445328
2010 camaro ss: Volant cold air intake, BBK Shorty Headers, JBA offroad midpipes, Diablosport tuned (custom tune), SLP II loudmouth axleback, ZL1 Short shifter, nitrous outlet wet "100 shot"
01-30-2017, 12:52 PM | #3 | |
Sent from my VS990 using Tapatalk
Romans 5:8 But God demonstrates his own love for us in this: While we were still sinners, Christ died for us. -Fastlane Cold Air Intake, NPP cat back exhaust, Stainless Works LT Headers, 2r max camshaft, Stage 3 Ported Heads (Manley Stainless steel values, titanium retainers, dual valve springs, bronze guides), Wiseco Forged Pistons, K1 Forged Rods, Clevite Bearings, Factory Crankshaft, Comp Cams rocker arm trunion kit, Morel 5315 lifters, JP performance single billet timing chain, Melling oil pump, Spec stage 3+ clutch and flywheel, BMR trailing arms, Nitto 555r 305/35/20. |
01-30-2017, 04:37 PM | #4 |
Drives: 2010 SS 2SS M6 Join Date: Aug 2016
did you replace the pilot bearing?
01-30-2017, 04:46 PM | #5 |
Nope I didn't replace it, probably should've. Now my clutch sticks (at idle I'm not driving it like that) and it's starting to smoke. Also sounds like some metal to metal grinding going on because the noise got worse
01-30-2017, 05:24 PM | #6 |
Actually the throwout bearing doesn't look bad, unless I'm missing something. This picture is from the vent on the transmission. Does a bad pilot bearing cause these symptoms? Sent from my VS990 using Tapatalk
02-05-2017, 03:18 PM | #7 |
Anyone have a pilot bearing fail?
02-05-2017, 05:18 PM | #8 |
Drives: 69 SS Camaro 2019 Corvette GS Vert. Join Date: Jan 2017
I have never had a pilot bearing fail in any car. As for you throwout bearing, the outside appearance does not mean a thing. When you are not pushing the clutch in, the bearing should not be in contact with the pressure plate. If it remains in contact, it will burn the bearing up. From the pictures, I can not tell if the bearing is in contact with the pressure plate or not. The bearing is not meant to continue spinning with the clutch engaged, only when you push the pedal down and disengage the clutch.
There is a fine line between hobby and obsession and I think I crossed it!!
02-05-2017, 06:02 PM | #9 | |
02-05-2017, 07:57 PM | #10 |
Hope your not driving the car while you are trying to figure out whats going on.
I had a Throwout bearing go in one of my cars and the bearing seized onto the input shaft of the tranny and snapped the input shaft off. It was a very expensive fix.
Mods, K&N CAI ,VTC , GM Perf Axleback Exhaust, Elite Eng CC and CSS, GM Strut Tower Brace,Carbon Fiber Anvil Spoiler,ASC T5 Splitter,Gen5diy Foglight kit.
02-06-2017, 05:43 PM | #11 | |
02-11-2017, 07:02 PM | #12 |
Anyone know how many Bellhousing to engine bolts there are. I'm trying to get the transmission off to diagnose this and it's stuck. Missed a bolt maybe? 1in gap at the bottom but can't get the rest even with a pry bar.
02-11-2017, 08:10 PM | #13 |
At least my bullet support bearing survived lol Sent from my VS990 using Tapatalk
02-11-2017, 10:51 PM | #14 |
WAS it the last bolt up top holding things up? Now that your this far, gonna do the pilot now? I guess the slave was not replaced when the clutch was upgraded? Hopefully all the measurements are on, why did the slave wear this bad? Drag race a lot? Hold the clutch to long? Or is bearing riding on the release fingers(I think there is a minimum clearance)..which gets slightly bigger as the clutch wears...
Hope you get it sorted and back on the road ASAP!
