02-08-2019, 09:55 PM | #1 |
Drives: 2017 Camaro 2SS Nightfall Gray vert Join Date: Jan 2018
Differences 2015 LT4 SC and 2019 LT4 SC
Just wondering if anyone can really outline the differences in the older LT4 Supercharger and the new 2019 model? I know the newer models have a taller lid, but what else is different?
2017 Camaro 2SS vert - Nightfall Gray
Magnuson Heartbeat SC - Tuned by JRE Racing 776whp/745wtq (12psi) 2018 Corvette Z06 vert- Black To be tuned by JRE Racing TBD performance Last edited by Drsagacity; 02-08-2019 at 11:06 PM. |
02-09-2019, 01:33 AM | #2 |
Drives: '99 Vette, '02 SVT Focus Join Date: Feb 2018
the Tall Lid LT4's came with angled intercooler core bricks to 'improve' (fix Z06 overheating) cooling performance, the cores are same thickness as original LT4 cores. nothing else on supercharger casting is different.
2019 HP/Tq. rating has stayed the same, so I presume (not seeing one in person) nothing on engine/supercharger has changed, doubtful since that would cost GM $$$$$$ |
02-09-2019, 03:37 AM | #3 | |
Magnuson Heartbeat SC - Tuned by JRE Racing 776whp/745wtq (12psi) 2018 Corvette Z06 vert- Black To be tuned by JRE Racing TBD performance |
02-09-2019, 02:13 PM | #4 |
No, the angled intercoolers are to 'tall' for short lid. What are your goals?
Maybe these dimensions could help you? and or others? https://wegnerautomotive.com/assets/...ers-Sep-18.PDF |
02-09-2019, 08:57 PM | #5 | |
Magnuson Heartbeat SC - Tuned by JRE Racing 776whp/745wtq (12psi) 2018 Corvette Z06 vert- Black To be tuned by JRE Racing TBD performance Last edited by Drsagacity; 02-09-2019 at 09:50 PM. |
02-09-2019, 10:03 PM | #6 |
Drives: SS 6 speed of course Join Date: Jan 2016
well that hood is super cool. It is worth it.
02-10-2019, 12:06 AM | #7 |
It’s for my Vette, not my Camaro. My Camaro is just about perfect as is. We will finish the tune and get into the 800’s next summer so we can make a few passes.
The Vette will stay around 600whp as it’s my daily driver.
02-10-2019, 04:38 PM | #8 |
The Vette guys says it hits the hood? Looks like it will clear without a hood insulator. But that is directly to cylinder head, are you planning to use LT1 to LT4 adapter plates so you dont have to drill heads?
02-10-2019, 05:17 PM | #9 |
Yes. I am using the adapter plates for the install. I was really just trying to figure out the differences that cause the lid to change. . .especially since the car never changed HP ratings, etc.
02-10-2019, 05:28 PM | #10 |
find someone, CTSV? that wants to swap you intercoolers/lid?
02-10-2019, 07:07 PM | #11 |
To make the new LT4 blower work, you are saying we just swap to smaller intercoolers and the shorter lid?
02-10-2019, 07:07 PM | #12 |
Drives: 2015 C7 Z06 M7 Join Date: Dec 2012
I don't think you can swap lid/intercoolers from the earlier to the later version, I believe it is a different SC housing. (but the new lid will fit on the old housing).
Should be plenty of the early generation 1740s around, they would be fine for what your looking for. The updated housing and lid had nothing to do with the "track overheating" issues of the Z06 (that is an engine radiator airflow problem), it simply improved an airflow distribution issue to the two rearmost cylinders on the LT4. In reality, by the time you scrape up all of the parts to make the system work on an LT1, might be easier it just get an off the shelf system which includes belt drive, coolant lines, front radiator, etc. |
02-10-2019, 07:48 PM | #13 |
Drives: 16' Camaro 2SS Join Date: Sep 2015
Call your local off the shelf system distributor and have a much better system overall with warranty.
@DeathWatchCamaro on Insta
993whp Magnuson 2.3R 9.5 @ 145, Magnuson 2300, Full Weight 2SS, 17’s (810whp) |
02-10-2019, 10:22 PM | #14 | |
