06-03-2018, 11:18 PM | #1 |
Drives: 2015 Regal Turbo, 2004 GTO Join Date: Jun 2018
Any piston issues?
Hey everyone,
In the market for a Camaro and have a love/hate relationship with the LTG. I currently have a 2015 Regal with the LTG and just cracked a piston at the ringlands. Warranty covered replacing the 4 pistons etc. I love the engine and have been driving turbo cars most of my adult life (Saab, Mazdaspeed, Regal) I have read on here that the engine is different enough to avoid these issues in the Camaro. Anything to confirm that is the case? The potential in this engine is incredible! The fact that stock its almost as fast as my GTO is just icing on the cake lol. Thanks for any info. |
06-04-2018, 06:08 AM | #2 | |
603 Camaros
Drives: 2017 NGM I4 1LT Coupe Join Date: May 2012
MY 2017 I4 CAMARO BUILD JOURNAL | YOUTUBE | INSTAGRAM | 316RWHP - 385 RWTQ HPTUNERS DYNO TUNE | 12.693s @ 105MPH 1/4 Mile |
06-04-2018, 11:25 AM | #3 |
Drives: 2016 camaro 2.0t gray Join Date: Apr 2017
06-06-2018, 07:42 AM | #4 |
Drives: 2010 Camaro Join Date: Nov 2009
The issue plagues all GDI engines, and especially forced induction versions. The issue is 2 fold, first is the poor design of the PCV system allows oil/water/gunk to accumulate in the intercooler and once it reaches enough it can be pushed into the combustion chamber and causes hydrolock. This we correct with our catchcan system designed for the 2.0T.
The second cause is LSPI. Low Speed Pre Ignition. This occurs when the excessive fuel pushed past the rings into the crankcase mixes with oil most and is pushed behind the top compression rings. If it ignites, it is a violent explosion and breaks the piston at the same area. This can also bend a rod and you will most likely not know aside from slight miss: This is also eliminated with our dual valve E2-X system as we provide full time evacuation flushing and removing these compounds and more from the crankcase. Then, Amsoil has reformulated all of their street oils to render these vapors non explosive. Mobile one recently did as well, but those are the ONLY oils were currently aware of that address this. And GM starting in model year 2016 made the piston thinker in that area so they are stronger and less prone to the common failures prior. Hope this helps all understand even more these are NOT the engines of the past, and the shortened warranty periods on GDI engines also reflects this. |
06-06-2018, 09:46 AM | #5 |
Drives: Camaro like Join Date: Jun 2017
In addition to Jason, don't forget that @SUN blew up his LTG, @Coolest Courier did as well, and at least 2 guys with 17/18 ATS. But, in every one of those cases, there was aftermarket tuning. Keep it stock and you have a very very low chance of any problems. Go for more power and the odds get worse.
06-06-2018, 12:05 PM | #6 | |
603 Camaros
06-06-2018, 01:40 PM | #7 |
Coopers Camaro
Drives: 18 Flex Fuel LTG Join Date: Nov 2016
OP, I can tell you GM global warranty LTG claims on piston related issues dropped significantly after the 2015 model year. This includes Cadillac, Chevy, and Buick. Some of that could be chalked up to mileage, but not to the extent of almost non-existence.
06-09-2018, 12:38 AM | #8 |
Drives: 2016 1LT RS Camaro; 72 Chevelle Join Date: Apr 2008
Right, Sun was pushing it, and so was I... I personally don’t know that I believe the coolests video of the blown boot... when I saw it I was like “wtf, this is your mechanic???” As he was Reving it multiple times to show the “issue”. More for YouTube drama i would hope.
Sent from my iPhone using Tapatalk |
06-09-2018, 12:43 AM | #9 |
Here’s my broken piston. Sent from my iPhone using Tapatalk |
06-09-2018, 05:03 AM | #10 |
Drives: Camaro Coupé 2.0T AT8 (EU version) Join Date: Mar 2016
Hi Notagto!,
just for your info, GM has released a service bulletin (17-NA-039) that suggests some strict kind of engine lubricants (low calcium oils).. "General Motors has identified an issue with the use of certain oils in the 2.0L turbo engine (LTG) that could result in premature engine piston failure. When performing an oil change on the 2.0L turbo engine, it is required to use a low calcium oil, ACDelco Dexos1 Full Synthetic 5W-30. If ACDelco Dexos1 Full Synthetic 5W-30 is not available, use Mobil1 Full Synthetic 5W-30 oil or Mobil1 Extended Performance 5W-30.". See you!!, Eos Last edited by Eos; 06-09-2018 at 05:10 AM. Reason: TSB number changed |
06-09-2018, 05:41 PM | #11 | |
06-20-2018, 02:29 AM | #12 |
Drives: Camaro 2.0 2017 8 speeds Join Date: Jun 2017
Yes at this time it s againe i think the 4 pistons... it s the third time i will open my enginefirst time 1-2 pistons second 4 and again 90psi on 4 , my Camaro is to. Paint shop at this time ( win fight with racoon, but with dommage) after that i will re open the engine to see the domage... maybe it s my error...the second time i blow engine is because i missed water/ meth in my tank...
06-20-2018, 05:48 AM | #13 |
ATS 2.0T
Drives: 2013 Cadillac ATS Join Date: May 2018
Anytime elite pushes their cans and designs to you remember one thing their design is flawed and when you show them it is flawed ask questions they will delete their thread. They make a great but very expensive can. Their system design is flawed and they do not list any install instructions on their site for the ltg motor. One very big why is this needed starts at their “you also need the clean side separator” just remember if their design was correct you should have no issue using the factory fresh air in port. They are just trying to sell bs.
06-20-2018, 09:05 AM | #14 |
603 Camaros
I think people generally know about elites can on here for now. Although people keep buying rpm as well.....
