Old 06-04-2019, 07:27 PM   #29
cooper1965
Coopers Camaro
cooper1965's Avatar
Drives: 18 Flex Fuel LTG
Here is mine from a bit ago in HPTuners
Flex Fuel tuned by me using HPT-:-
---My Build Thread---
-----My IG PAGe-----
cooper1965 is offline   Reply With Quote
Old 06-04-2019, 07:28 PM   #30
cooper1965
Coopers Camaro
cooper1965's Avatar
Here is "another" LTG in hpt
Old 06-04-2019, 09:20 PM   #31
turbojeep95
turbojeep95's Avatar
Drives: 17 Camaro lt, 22 Camaro LT1
Wow! That torque number is brutal! Were did that run come from?
turbojeep95 is offline   Reply With Quote
Old 06-11-2019, 10:50 PM   #32
Delpy
Drives: 16 Camaro 2.0 6spd ,08 caliber srt4
Nice Coop!!
I actually moved near a gas station with e85 so might start mixing some. I’ve added some but only with minor changes to the tune that commands a few less psi.
C’mon there’s gotta be some mor LTG guys with accesses to data logging equipment, Post up your stuff.
Delpy is offline   Reply With Quote
Old 06-14-2019, 09:57 PM   #33
wookwook
wookwook's Avatar
Drives: 18 Camaro LS M6
I just happened to meet the UPS guy on my way out to the strip, and took delivery of my zzp catted DP. So that is next.
the car is basically stock with a race chip RS the first clip is a quarter mile on setting 2. I have a Jac valve and it didn't code tonight. Hasn't coded since the runs last week. So maybe it was a seating thing. I also have a midpipe resonator which gives a very enjoyable touring ride w/o any raspy drone, but clearly hampers the high end performance. Working on a work around.
2 things i think I proved, judging by the calculated 0-60 vs radar, the stock goodyears are slipping pretty badly off the line. .5 to 1 second deltas there.
The torque sensor in 4th seemed to be lower by about 25 on this surface. I don't know if that is attributed to the car being in motion, so there is some delta from measuring a car on a machine. I got much better on good old street asphalt matching the dyno closely.
This first one is with the race chip on 2 of 6.
https://youtu.be/QwD1tAZmouM
This next one has NLS and you can see it holding the throttle position less closed by the square bottom and the rpm graph. RC is on 4.
https://youtu.be/HgJYt3nG-lk
next is best run topping at 103. RC on 5 of 6. some pinging. the spark advance is clearly increased. NKGs 6510's @ 0275.
https://youtu.be/YT_1tsm2SDU
Hope its informative.
wookwook is offline   Reply With Quote
