09-23-2018, 08:09 AM | #1 |
Drives: 2017 2SS A8 Black Join Date: Mar 2017
lowering springs installed....slight speed bump.
So I installed the BMR lowering springs on my 2SS MRC yesterday. The tie rod link for the sway bar and the top bolt on the strut require an 18mm pass through socket. You will need a deep well or pass through extension for the strut bolt. They have a 6mm and 5mm hex in the middle of the bolt that has to be held in place while turning the nut....Pics below show the tie rod bolt. My strut bolt was the same.
Man is born free, and everywhere he is in chains
09-23-2018, 08:54 AM | #2 |
Drives: Camaro 50th anniversary edition Join Date: May 2017
And? I don’t understand the headline. Do I miss something here?
Soleil
_____________________________________________ A car is fast enough, if you fear to unlock it in the morning." (Walter Roehrl) |
09-23-2018, 09:46 AM | #3 |
Drives: 2020 Camaro 2SS Join Date: Aug 2009
He's just letting us know that its not just a simple slap a socket on and go, there's more to it. Hence the "speed bump". Thank you to the OP. Good info.
09-23-2018, 12:57 PM | #4 | |
(none of the videos we watched showed this....maybe the impact wrenches zip it off but we used regular hand tools..)
