Old 04-16-2021, 06:31 PM   #1
adman98
adman98's Avatar
Drives: 2021 Camaro 1SS M6
No "Launch Control" on Competitive Mode (scratching head)
Hey guys, I've looked for a few hours on here-and got side tracked reading many many posts btw, but I can't find any info on my question of-Does Competitive Mode not include Launch Control on some 1SS models?
I hit my traction control button twice and "esc/Competitive Mode" reads on my screen, but I can't get it to "launch". I also only have 9 of 9 pages for the performance screen. I don't have the "Disabled" Launch Control screen.
My car is a manual so I put it in track mode and hit t/c button twice for c/m and I have my car in first gear and the clutch all the way down, but when I slam on the gas it just revs towards 6k and does not stabilize to "set up" a launch.
Just curious if my car needs a flash from the dealer or does my car/vin/model not have any launch control capabilities?
Thanks
2021 Camaro RS 2.0Turbo SOLD
adman98 is offline   Reply With Quote
Old 04-16-2021, 06:44 PM   #2
vtirocz
vtirocz's Avatar
Drives: 2017 Camaro 1SS M6
Does engine speed stabilize at ~4000 - 4500 rpm? Accelerator pedal to 100%?
Old 04-16-2021, 06:47 PM   #3
enzia35
Drives: '16 Garnet Red 1SS
Page 225 here:
https://my.chevrolet.com/content/dam...ro1stPrint.pdf
'16 Camaro 1SS
'18 Miata GT
Gone: '01 Camaro, '14 Camaro, '90 Miata
enzia35 is offline   Reply With Quote
Old 04-16-2021, 06:59 PM   #4
adman98
adman98's Avatar
NO it goes towards 6.5K and I let up because I don't want to redline it.
Originally Posted by enzia35 View Post
I've read this 2 dozen times, but I can't get it to work. Am I also supposed to be able to adjust the "slip" or rpm range I want to launch in-from a menu or something?
Old 04-16-2021, 07:00 PM   #5
adman98
adman98's Avatar
Does line lock come on certain models whether auto or manual? Or just the 2SS?
Old 04-16-2021, 08:46 PM   #6
enzia35
Nah, I don't think there's anything like that. I've never used it personally. But it may adjust the RPM based on temp and junk like that.
'16 Camaro 1SS
'18 Miata GT
Old 04-16-2021, 08:59 PM   #7
vtirocz
vtirocz's Avatar
If you abruptly floor it under those conditions, it should work. It would overshoot the ~4k rpm target and then come back down. I wonder if you're not allowing it enough time to settle or not flooring it abruptly enough? It's standard on all SS cars, it's not an option and as long as you are in competition mode it should work.
Line lock was on the auto SS only, not the manual SS. 1SS/2SS wouldn't matter.
Old 04-16-2021, 09:51 PM   #8
adman98
adman98's Avatar
Thank you sir for this. I may have been a little paranoid on over revving it so you're probably right, I wasn't giving it time to stabilize. I'll let you know tomorrow-unless I kill it, then I'll be heading to mexico. arriba arriba..
Old 04-17-2021, 02:20 PM   #9
s346k
s346k's Avatar
Drives: like an old lady
be sure to firmly press the brake before you rev the car up.
2016+ camaro: everyone’s first car
s346k is online now   Reply With Quote
Old 04-19-2021, 03:54 PM   #10
jimadvig
Drives: 2018 Camaro 1SS
You need to make sure you have the clutched pushed all of the way to the floor while in 1st gear and then mash the skinny pedal to the floor as well. It will rev up to around 5k then level off around 4300-4500. I actually tried it for the first time the other day just to see if it worked. It did.
Camaro 1SS M6 - LT2 IM, 1-7/8" Speed Engineering Headers & catless 3" x-pipe to Borla ATAK NPP axle back, Mishimoto Catch Can, BTR Rocker Arm Trunnion kit, E85, 95MM TB, JLT CAI, 180* T-Stat, & SJM line lock - Tuned by Ted Jannetty
jimadvig is offline   Reply With Quote
Old 04-20-2021, 08:19 AM   #11
Rhobz
Rhobz's Avatar
Drives: 2018 Camaro 1SS 1LE
In my 2018 1SS 1LE it seems super finicky, enough to make me question it like you are. It requires the steering wheel to be straight and the clutch pedal to be on the floor. It seems like the wheel has to be PERFECTLY straight and you have to be trying to push the clutch through the floor. When it does engage, you can tell right away. It also seems like the ground has to be perfectly level. I tried it on a road that had a very slight crown and couldn't get it to engage. The engine revs faster than the RPM gauge sweeps so there is a huge difference in the sound/feel when you mash the gas pedal between when Launch Control is activated and when its not.
Rhobz is offline   Reply With Quote
Old 04-21-2021, 05:37 PM   #12
adman98
adman98's Avatar
Thanks guys, I got it to work. The wife was in the car when I tried it. She's not big on the power-scares her, but she enjoyed the ride. It was a good launch with not much wheel spin so I'll have to try it again with the 0-60 timer. It is LOUD holding at 4300k rpms in track mode. But impressive with the technology from Chevy for that type of launch with a manual.
Old 04-21-2021, 08:11 PM   #13
arpad_m
arpad_m's Avatar
Drives: 2018 Camaro 2SS A8
There's your recipe for success
735 rwhp | 665 rwtq
3000 - 2/06/18 TPW 2/26/18
Old 04-21-2021, 08:48 PM   #14
1LE_L1FE
Drives: 2017 Camaro SS 1LE
FWIW seems like magazines got quicker launches without launch control anyway - 2k RPM in the SS 1LE.
1LE_L1FE is offline   Reply With Quote
