10-10-2023, 09:20 PM | #1 |
Drives: Camaro 2SS Gen 5 Join Date: Oct 2023
2015 2SS HID headlights..... are TERRIBLE
So, what gives? I saw on my window sticker that my Gen 5 2015 2SS has factory HID headlights..... but it's terrible. I did my first night drive tonight, and was shocked at how bad it is.
Light output and "focus" both leave allot to be desired. Is this typical? How do I get awesome illumination? Thanks in advance!!! |
10-16-2023, 10:15 AM | #2 |
Drives: 2010 Camaro SS manual Join Date: Feb 2022
The factory HID:s have been great when new, but the reflecting surfaces go bad and and both output and focus go to toilet. You can replace the whole unit or retrofit new and better hid units to the original headlamp. I retfitted new hid units in my 2010 hid lamps and they have been great!
2010 Camaro SS, LS3 + 6spd manual.
1975 Volvo 242, 357SBC + 6 spd manual. 1978 Blazer offroader with LS1, 1-ton axles. |
10-16-2023, 02:16 PM | #3 |
I just installed some Osram "Night Breaker" bulbs..... problem solved. HUGE difference!!
https://www.osram.com/am/campaigns/nightbreaker.jsp Thank you Tommi, for the suggestion. |
10-16-2023, 02:58 PM | #4 |
Drives: 2016 1SS Join Date: Apr 2012
HID Bulbs
We offer the Diode Dynamics DS3 Bulbs. These are great replacement bulbs.
10-16-2023, 03:49 PM | #5 | |
CamaroFans.com
10-16-2023, 08:32 PM | #6 |
Drives: 2010 Camaro 2SSRS M6 Join Date: Jan 2019
10-19-2023, 03:36 PM | #7 |
Drives: 2010 Camaro 2SS L99 Join Date: Apr 2023
Headlights have always been weird to me, I don't think I've turned high beams on in any car I've driven for better part of a decade, but I guess I only maybe see half a dozen deer a year and drive at night mostly just in the winter when it gets dark before I go home. Have actually had the opposite problem, especially with newer cars where just standard lights are enough to blind you, especially if you're driving on a hilly road and the car behind you crests and flashbangs you with their low pointed lights, my favorite is when someone is driving behind you and you can see the shadow of your car in your headlights in front. Buying aftermarket lights also becomes a whole thing because each one just advertised how much brighter they are while I just want to maintain same brightness maybe change the color temp and that's it. Anyways that was my yelling at clouds moment, funny enough when I bought my Camaro I was surprised that my old HID lights were better then the car I drove beforehand, lol.
Behind every scratch is a story on what not to do, and my car has a lot of stories.
11-01-2023, 04:48 PM | #8 | |
Drives: 2010 2LT/RS Join Date: Mar 2015
What style halogen lamp did you go with? H1, H4 or H7? and how much are the set of bulbs going for? Website doesn't indicate and says to contact them. If these are replaceable without removing the bumper to take off the headlights to access through the rear then that's great! I did that once taking apart the headlights to fix my Halo issues. Been putting off the halogen bulb replacement for awhile now. I have the custom bracket for the the Morimoto HID retrofit and just haven't done it yet.
2010 2LT/RS
ZL1 Appearance package, Flow Master American Thunder Cat Back Exhaust w/ QUAD TIPS, K&N Typhoon CAI, Ported VMAX TB, OEM GM Brembo Brakes Package w/ Hawks Carbon Ceramic Pads, Night Owl Halo Kit (WIFI), FRONT/REAR Carbon Fiber Wrapped Bowties, Rear Oracle Blue LED Bowtie, Oracle Ghosted Painted Side LED Markers, Silver Side Faded Gills, OEM Satin Camaro Fuel Door, OEM Strut Tower Brace, Detroit Speed Engineering 1.5" Lowering Springs, Koni Orange STR.T Struts, Z28 rear LCA's, Black Magic rear 32" sway bar, 1LE front sway bar w/ DSE end links. Evil Energy Catch Can. |
11-10-2023, 09:33 PM | #9 | |
Sent you a PM since I haven't heard back from you with a response. Hope to hear from you soon on what choice bulb you went with.
2010 2LT/RS
