09-05-2023, 01:05 PM | #1 |
Drives: Synergy Green, 2011 Camaro SS Join Date: Aug 2013
Vertical doors inc shock
Hey Camaro 5 team,
I have the vertical doors from VDI.com and need to know the LBs for the replacement shock. My shock no longer holds the door open. I can get one from other vendors I am sure. The ones from VDI are so expensive. I just need to know the LBs for the shock, 750, 800 or 850 LBs. Thanks in advance. |
09-05-2023, 07:06 PM | #2 |
Drives: 2010 Camaro 2SSRS M6 Join Date: Jan 2019
This looks like the only two they offer. So I would think it’s one of these.
09-06-2023, 07:24 AM | #3 |
Thanks
You can buy the shocks from somewhere else for 1/4 the cost or around 40 bucks. Just need to know if anyone knows the LBs for the original shock. I would like to go up about 50lbs to make the door lift easier and hold open better. |
shocks, vdi |
