AWE Tuning
Old 05-18-2020, 12:37 PM   #1
Mot700
Mot700's Avatar
Drives: 2019 Chevrolet Camaro 2SS
Unhappy 2019 2SS Park Assist - not working like it should
I have a 2019 Camaro 2ss and every time I put my car in Reverse it says park assist off. When I go to the Collision detection system menu everything is turned on including park assist but when I'm in reverse and backing up into the driveway there are no beeps or indications on the rearview camera that there's any kind of detection. I've only had this car a few weeks and I've read the owner's manual. I've looked at my Chevrolet app for support and I don't see any specific references to the Camaro park assist only the generic Chevrolet park assist. If I am doing anything wrong please tell me, I would really appreciate it! I'm really unsure of what is going on.
Mot700 is offline   Reply With Quote
Old 05-19-2020, 08:59 AM   #2
Mot700
Mot700's Avatar
Does anyone have any suggestions?
Sent from my SM-G960U using Tapatalk
Old 05-19-2020, 12:26 PM   #3
Mark114
Mark114's Avatar
Drives: 2016 2SS Convertible
If it is a new car then maybe one of the sensors isn't working and that disables park assist? You may need to take it to the dealer to run diagnostics.
Mark114 is offline   Reply With Quote
Old 05-19-2020, 02:35 PM   #4
Mot700
Mot700's Avatar
Yeah, I was trying to avoid going to the dealer unless I had to, but if I am not doing anything wrong, I don't know what the deal is. Thinking about asking OnStar too.
Old 05-22-2020, 01:09 PM   #5
Mot700
Mot700's Avatar
Just in case anyone was interested, took it to the dealership yesterday and found the issue and fixed it. A hidden low voltage code was blocking the park assist function. Once they cleared the code it started working fine. Never had a check engine light so I never knew. Reason it probably happened was that this car was sitting in the showroom and never test driven, so the battery was probably drained before I bought it.
Old 05-22-2020, 05:09 PM   #6
NiteBlitz
Drives: Camaro ZL1
Glad it was an easy fix.
NiteBlitz is offline   Reply With Quote
Old 05-25-2020, 04:23 PM   #7
avalonandl
avalonandl's Avatar
Drives: 2019 ZL-1
If you can put a Battery minder 1510 on it- Its a Battery tender with a desulfarator mode....really works. These AGM batterys need that. Mine is 3 years old and my battery % went from 70% to 90 % in 10 days......
These cars have variable charging systems and sometimes when you are driving it wont charge and you put the car away at 12.3 v.....The tender keeps voltage up....
2019 ZL-1 Acquired 4/23/21 at 6300 miles. Riverside Blue, A10, PDR. Traded in 2017 2SS with 6M and 32k miles. Continental Extreme Contact Sports. Now has 10,000 miles...
2012 Yukon XL Denali w/ 6.2 AWD
avalonandl is offline   Reply With Quote
Old 03-05-2022, 11:30 PM   #8
1 Hot Red
1 Hot Red's Avatar
Drives: 2021 Riverside blue 2SS 1LE
Hey mot700 did the dealership actually fix or look into the low voltage code ? Or did they just clear it ? Today I was driving back home from a 2 hour trip when I left the parking assist worked when I came home I was experiencing the same situation as you guess I need it scanned as well
1 Hot Red is offline   Reply With Quote
Old 01-21-2023, 08:49 AM   #9
CGMLT
CGMLT's Avatar
Drives: 2019 2SS 1LE
I'm having the exact same issue on my 2019 2SS. Will have to check and clear any codes and see if that does the trick...
Wooo Hooo... 2019 2SS 1LE!!!
CGMLT is offline   Reply With Quote
Old 08-11-2023, 05:29 PM   #10
2ndCamLuv
Drives: 19 Cam 2SS Manual
What did this end up being. My cars sits in garage most of the time and battery is new. I show no codes with my scanner. Do I have to use like dbr scanner?
2ndCamLuv is offline   Reply With Quote
2ss, parking sensor
