Roto-Fab
Old 11-12-2023, 01:47 AM   #1
Camaro2ss6speed
Drives: Chevrolet Camaro 2ss
Need help
So today I drove my Camaro 2011 Camaro 2ss 6 speed and when engaging in reverse my lights don’t turn on but when I pop the trunk they turn on I’ve been researching and found bad reverse switch I have been looking where is this located at and cannot find an answer do I need to remove my center console?
Camaro2ss6speed is offline   Reply With Quote
Old 11-12-2023, 08:02 PM   #2
Camaro2ss2010
Camaro2ss2010's Avatar
Drives: 2010 Camaro 2SSRS M6
It is typically by your transmission so you may be able to access it from under your car.
Camaro2ss2010 is offline   Reply With Quote
Old 11-13-2023, 02:17 PM   #3
Camaro2ss6speed
thank you i will look for it
Old 12-12-2023, 05:54 PM   #4
Camaro2ss6speed
So I found it and I guess I ordered the wrong one also… is there a special tool to even take these out? My 22 wrench only loosens it up and I can’t turn it ��
Old 12-12-2023, 06:36 PM   #5
Camaro2ss6speed
Is this the switch? After disconnecting it and turning on my car I don’t get the reverse camera on my stereo after connecting it turns on so my question how can I remove this? I fit a 22 mm but it only moves a little after that wrench hits on the side
Old 12-14-2023, 10:17 PM   #6
Camaro2ss6speed
i figured it out.. the black plug with orange removes with a screwdriver and then you can remove the plug <3 geez.. couldn't find this anywhere
