Old 10-17-2020, 11:44 AM   #211
zain
zain's Avatar
Drives: ZL1
Alignment every oil change!
zain is offline   Reply With Quote
Old 10-17-2020, 12:11 PM   #212
mlee
CamaroFans.com
mlee's Avatar
Drives: ZLE & ZR2
Originally Posted by Harry76 View Post
Steven just duplicated the issue at the end of that video.
I really don't think tire was the cause because mine did the same thing on the drag strip with stock tires.
Old 10-17-2020, 12:34 PM   #213
NEZL1
Drives: ZL1 1LE
So quick update. Made a bit of a discovery accidently.
I was already coming to the end of the life of my Cup2s up front, and I corded them quicker then I thought. So in a pinch I bought some RE71Rs for the front (planning on going V720 ACR tires out back once they're back in stock)
But tramlining is deff part of the problem, and my alignment might have shifted as well so I'm going to check it but the tires are without a doubt part of the issue.
Now the rear end might squirm ever so slightly. but it's just not at all terrifying any more. I think what was happening was that the rear was tramlining, and then when you put a little input into the wheel the front would tramline as well, making the whole car feel like it was all over the road.
With the front's no longer tramlining, the car all of a sudden magically is much much more settled. Like 75-80% better.
Surprised, so I'll be checking alignment to make sure there are no changes there as well, but I can say from this that tire choice can certainly exacerbate this issue.
So I think eventually as a community we'll figure out that if you have X brand tires, likely you'll want a different alignment, then another brand of tires.
Funny enough the Re71's up front are MUCH more stable then the Cup2s. They feel more numb in Auto-X style maneuvers. But ripping up the backroads the other day they set into a corner and inspire confidence mid corner. So I'm not sure they're the most responsive tire, but it this case, a less manic nature actually helped the situation.
NEZL1 is offline   Reply With Quote
Old 10-17-2020, 03:43 PM   #214
Mark R
Drives: 2018 ZL-1
I align my car every 2000 miles, and it is always out of spec.
Mark R is offline   Reply With Quote
Old 10-17-2020, 04:15 PM   #215
zain
zain's Avatar
Drives: ZL1
Does that include replacing the rear alignment bolts?
Old 10-17-2020, 05:53 PM   #216
Mark R
Drives: 2018 ZL-1
No. They have not been replaced yet. But i have a set for next time.
Old 10-17-2020, 09:13 PM   #217
JonDaddy82
JonDaddy82's Avatar
Drives: 2018 ZL1 Coupe NFG M6
If you have to align your car every 2,000 miles...you sir, have a mechanical problem.
1989 Forumla 350 WS6 <- High School
2000 Trans Am Firehawk <- After High School
2017 Colorado Z71 <- Daily
2018 ZL1 M6 <- Not Daily
JonDaddy82 is offline   Reply With Quote
Old 10-17-2020, 10:01 PM   #218
Mark R
Drives: 2018 ZL-1
I don't think so. It does not feel out of alignment, but I purchased lifetime alignment from Firestone, so there is literally no downside to bringing it in. It costs me nothing.
But every time I take it in, it is out of spec by a little bit. And I have a full BMR suspension setup.
Old 10-19-2020, 05:44 AM   #219
Bangkok_ZL1
ZL1 Believer
Bangkok_ZL1's Avatar
Drives: 2019 Camaro ZL1
DAMN
Bangkok_ZL1 is offline   Reply With Quote
Old 10-19-2020, 07:49 AM   #220
JonDaddy82
JonDaddy82's Avatar
A set of BMR toe arms might be a good idea. You can lock them in and not loosen the one time use bolts every time. That might be your problem since you haven’t been replacing the bolts you said.
Old 10-19-2020, 09:52 AM   #221
Mark R
Drives: 2018 ZL-1
I had the toe rods installed this summer for that very reason. The toe moved only a little bit since installation.
I actually brought the bolts to Firestone last week to have them installed, but they didn't quite get the message, and did not install them for some reason, though they did the alignment. Next time I have the car aligned, I will be more clear and have the bolts put in.
Old 10-19-2020, 12:12 PM   #222
Mark R
Drives: 2018 ZL-1
Here are the before and after measurements. Not out a bunch, but enough that free alignment is worth it. This is after about 2200 miles.
Old 10-19-2020, 12:25 PM   #223
Bangkok_ZL1
ZL1 Believer
Would the following thread have anything to do with this thread? It seems to answer the issues you all are having with rear end alignment going on the blink.
https://www.camaro6.com/forums/showthread.php?t=502324
Old 10-19-2020, 12:35 PM   #224
Mark R
Drives: 2018 ZL-1
Yes it would. I think this car, with the power, the ELSD, its sensitivity to alignment, and tire width / tramlining, all combine to contribute to the tail wag on acceleration. I wish Firestone had replaced the bolts last week, but somehow that got lost in translation.
Next time.
