Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Regional Forums > USA - Mid-Atlantic > Local Marketplace
Old 02-27-2017, 10:16 AM   #1
edog
edog's Avatar
Drives: 2010 2SS/RS IOM
10" 6L80 Lock Up XHD LS 2800 - 3200 [10080LS] SOLD
Selling my 10" 6L80 Lock Up XHD LS 2800 - 3200 [10080LS]. No issues with the stall up to removal. I purchased new in May 2014 during my Cam upgrade. It was installed from May 14 to August 16. Has 17k on it. Light track time. Street tire use only while installed. Great for naturally aspirated application.
Upgraded to a ECS supercharger this Summer. Sent Trans out to be upgraded and upgraded the Stall to a Pro Yank 3600 10.5" converter. Mickey Thompson ET Street R time!!!
Looking to let it go. Need to open up space in garage.
SOLD
http://www.camaro5.com/forums/showthread.php?t=485831
Update...Build in process, Forged Rods, Pistons and rings, Johnson Lifters, NOVI1500 ECS SC, 13lb boost or more, LS3 Conversion 114/228/241 COMP CAM, Frostbite 4 row Aluminum radiator, 6L80 built, Circle D 6L80 PRO SERIES MULTI 258MM 2D, Stock 3.45 gears, 1-7/8 American Racing Headers w/HF cat, X-Pipe, Lingenfelter dual fuel pump, E-85 flex sensor, ATI super damper pulley, Ported TB, 160 therm, Trans cooler, Pedder's sways/end links/sub frame bushings, BMR trailing arms & toe rods, Coil overs. HP/TQ pending
edog is offline   Reply With Quote
Old 02-28-2017, 08:39 PM   #2
edog
edog's Avatar
Bump
Sent from my 2PS64 using Tapatalk
Old 03-13-2017, 12:33 AM   #3
edog
edog's Avatar
bump
Old 03-26-2017, 07:30 PM   #4
edog
edog's Avatar
bump It's a great converter.
Old 03-31-2017, 12:53 AM   #5
edog
edog's Avatar
bump
Old 04-04-2017, 07:01 AM   #6
edog
edog's Avatar
bump
Old 07-09-2017, 07:56 PM   #7
edog
edog's Avatar
bump
Old 07-22-2017, 08:05 PM   #8
edog
edog's Avatar
bump
Old 08-30-2017, 09:56 PM   #9
Tkandrews
Drives: 2011 Red Camaro 2ss
Are you willing to do 400 shipped PayPal ready upon your answer
Tkandrews is offline   Reply With Quote
Old 08-31-2017, 07:33 AM   #10
edog
edog's Avatar
I would be willing to do 400 and buyer pays shipping. I cannot get rid of it that cheap. It's a good unit.
Old 08-31-2017, 12:05 PM   #11
Tkandrews
How much is shipping to 31320 ga
Old 08-31-2017, 01:17 PM   #12
edog
edog's Avatar
Ups ground shows 30 dollars. I used a address on Charles St with your zip code. I used 30lbs, but if not as much should be cheaper. Worst case 30 dollars. Only thing which will increase it would be if you want to insured.
37.15 if you want it insured for full value of 800. Take away cost if you want less insurance. I think 400 was 35.
Old 10-16-2017, 01:29 AM   #13
edog
edog's Avatar
SOLD
