08-25-2018, 04:46 PM | #1 |
Drives: 2017 1SS Hyper Blue Join Date: Apr 2017
Good deal on rims but 35mm offset
Found a good deal on some KMC district wheels, but all 4 are 10.5” wide and 35mm offset. What would I need to run these? I think a 7mm spacer on rears, but will that work with stock length studs?
How about the fronts at 35 mm? |
08-25-2018, 05:12 PM | #2 |
Drives: 1SS 1LE Join Date: Jul 2018
08-25-2018, 05:13 PM | #3 |
Drives: SS-6-SPD Join Date: Jan 2017
If you have a Brembo brakes you will need a 10mm spacer for the front.
The rear should fit without a spacer. |
