Old 08-25-2018, 04:46 PM   #1
wwiiavfan
Drives: 2017 1SS Hyper Blue
Good deal on rims but 35mm offset
Found a good deal on some KMC district wheels, but all 4 are 10.5” wide and 35mm offset. What would I need to run these? I think a 7mm spacer on rears, but will that work with stock length studs?
How about the fronts at 35 mm?
wwiiavfan is offline   Reply With Quote
Old 08-25-2018, 05:12 PM   #2
Wontspeak
Wontspeak's Avatar
Drives: 1SS 1LE
http://www.tire-size-calculator.info...&2off=23&2ws=0
Wontspeak is offline   Reply With Quote
Old 08-25-2018, 05:13 PM   #3
cmeJATT
cmeJATT's Avatar
Drives: SS-6-SPD
If you have a Brembo brakes you will need a 10mm spacer for the front.
The rear should fit without a spacer.
cmeJATT is offline   Reply With Quote
