08-08-2020, 03:12 PM | #1 |
Drives: 18 ZL1 nightfall grey A10 Join Date: Apr 2018
BMR suspension.
I’m looking to buy some suspension from BMR. I’m thinking about upper/lower control arms and trailing arms. I want to go the non-adjustable route because I want to keep things as simple as possible. Will these help with launching from a dig? Are there any negatives to using these? Is the lock out kit a necessary item? If so, doe it have to be the one with the bullets?
Any advise you can give is appreciated. |
08-08-2020, 03:26 PM | #2 |
Drives: 2019 ZL-1, Shadow Gray, Sold Join Date: Jan 2019
Yes, Yes and Yes. Did mine a couple of months ago and makes a world of different in the backend.
08-08-2020, 03:27 PM | #3 |
Drives: 2018 ZL1 Coupe NFG M6 Join Date: May 2017
I have all the non-adjustable stuff, car feels great. Zero negatives about doing them other than a slightly lighter wallet.
1989 Forumla 350 WS6 <- High School
2000 Trans Am Firehawk <- After High School 2017 Colorado Z71 <- Daily 2018 ZL1 M6 <- Not Daily |
08-08-2020, 04:52 PM | #4 |
The lock out kit looks pretty involved. I was hoping to get away with just the arms. Lol!
08-08-2020, 06:46 PM | #5 |
Actually the lock out kit wasn't terrible. I have a lift though and that certainly helped.
08-08-2020, 07:17 PM | #6 |
Drives: 2017 ZL1 A10 & 2021 BMW M340i x Dr Join Date: Mar 2009
I did all non adjustable as well as lockout kit. For me it was immediate improvement. Luckily I was able to have one of the guys from BMR install them all.
Sold 2012 2LT RS 12.3@112 old setup
Sold 1967 Camaro Pro Street. Ran 10's mild BB on NOS. 2017 HyperBlue ZL1 A10 ** Born 3/17/17**Delivered 4/08/17 2020 Build: Mag2650, BTR Stage2, NW103, BG, 14% lower, 90mm upper, ARH 2" Long system w/no cats, SW Legend mufflers. **807hp/762tq on 93 gas** and **848hp/792tq on e47** Sold 2018 (Go Mango) Dodge Charger Daytona 392 Daily Driver Daily Driver 2021 BMW M340i Xdrive |
08-09-2020, 08:59 AM | #7 |
Drives: 2018 ZL-1 Join Date: Jan 2018
The lockout kit is probably more important than the arms. I have the arms and lockout kit. You might as well get the toe rods and do that while you are there.
These components will make a significant improvement to the car. |
08-13-2020, 06:41 AM | #8 |
Well I bit the bullet and bought both lockout kits, upper and lower control arms, and trailer arms. I’m hoping all this helps me put the power down.
08-13-2020, 09:20 AM | #9 |
08-13-2020, 09:26 PM | #10 |
08-13-2020, 10:05 PM | #11 |
be careful with the differential lockout for the top bolt on the differential. This is not solid on a ZL1 1LE. The front differential lockout locations work fine. You must replace the top bolt as it is a TTY bolt in that location. BMR directions have no mention of it.
08-14-2020, 09:09 AM | #12 | |
08-24-2020, 08:58 PM | #13 |
Drives: 2015 Z/28 Join Date: Jun 2011
Are the bolts for the upper/lower control arms and trailing arms TTY bolts that should be replaced?
08-24-2020, 09:25 PM | #14 | |
I highly recommend you buy the bolts online. Through my local stealership all the bolt come out to $150. If you buy online it’s about $100 dollars for everything shipped. |
